leabassett@sbcglobal.net 156 #1 Posted October 31, 2023 My 1987 312-8 Has no size on the rear tires. I need to get a tube for one. Anyone know the exact size? I keep getting different things from different sites. Thanks 3 Share this post Link to post Share on other sites
ebinmaine 70,704 #2 Posted November 1, 2023 Check the inside of the tire carefully. I've NEVER seen a tire that wasn't marked. That said.... A tube that fits a 23 x 8.5/9.5 x 12 should get you outta trouble. 5 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 156 #3 Posted November 1, 2023 Check the inside of the tire carefully. I've NEVER seen a tire that wasn't marked. That said.... A tube that fits a 23 x 8.5/9.5 x 12 should get you outta trouble. I looked inside and out. There is no marking at all not even a PSI. Tiers look original too. 2 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 156 #4 Posted November 1, 2023 There is no chub rub on them either. 2 Share this post Link to post Share on other sites
Pullstart 64,510 #5 Posted November 1, 2023 If you could give us a good quartering away shot, we could guesstimate close enough! 2 Share this post Link to post Share on other sites
Racinbob 11,720 #6 Posted November 1, 2023 OE was 22 x 9.00-12 but they are easily changed. The tubes mentioned will work fine. 4 Share this post Link to post Share on other sites
Pullstart 64,510 #7 Posted November 1, 2023 I believe it’s @pacer who has mentioned being involved with planes in the past. A SMALLER tube a bit stretched is always better than a LARGER tube that could fold inside the wheel and tire. 2 1 Share this post Link to post Share on other sites
ebinmaine 70,704 #8 Posted November 1, 2023 4 minutes ago, Pullstart said: I believe it’s @pacer who has mentioned being involved with planes in the past. A SMALLER tube a bit stretched is always better than a LARGER tube that could fold inside the wheel and tire. Agreed. Fold or crease can create a friction spot which eventually might lead to a rupture. 1 Share this post Link to post Share on other sites
ACman 7,630 #9 Posted November 1, 2023 40 minutes ago, ebinmaine said: Agreed. Fold or crease can create a friction spot which eventually might lead to a rupture. … I wish I knew how many tractor an implement tires I’ve mounted and or patched back in the day all by hand . Seen it many times with tube folded or pinched leading to a leak . I would always blow up the tire then let the air out then refill . Inner tub powder is your friend too and pay attention to the valve stem size as it may need a bushing so it fits tight in the hole in the rim . Good luck 1 1 Share this post Link to post Share on other sites
ebinmaine 70,704 #10 Posted November 1, 2023 1 minute ago, ACman said: and pay attention to the valve stem size as it may need a bushing so it fits tight in the hole in the rim That is something right there that I just NEVER remember to check 2 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 156 #11 Posted November 1, 2023 Thanks for all the replies. A 23 x 8.5/9.5 x 12 Tube I will get. The tires look a little fatter than what is on my John Deere 140. 1 Share this post Link to post Share on other sites
