moe1965
K series fuel bowl gasket
moe1965
I have a 10 hp Kohler that is in need of a fuel bowl gasket  my question is are all the fuel bowl gaskets the same 8 ho through 16 ho?
squonk
As long it's a Kohler carb then yes. Walbro carbs are different.
Bowl o ring    200375 S
baffle gasket  25041 02 S
Kit   25 757 01
  • Like 3
WHX??
I get the cheap kits off flea bay. Throw away the inlet parts they don't fit. Just use the gaskets for those quick bowl cleanings. Couple of dabs of grease hold them in when on the tractor.
Full blown cleanings use Kohler kits.
  • Like 3
squonk
You even have to watch what your buying. I ordered  2  25-757-01 "Kohler carb kits off of the jungle. I got clear bags with a little sticker with Kohler "25 757 01 Made in China" instead of the blue and white packaging with the big "KOHLER" script
