Found this today .
image.jpeg.8434393afd3f2103a1f23b8b1ad5a485.jpegI started putting a 8 speed 1.1/8 inch axle transmission in my 1056 and found this . Time to break out the welder . The extra 2 holes are to tie in some extra metal . So hopefully this doesn’t happen again .
  • Like 5
  • Sad 3
ri702bill
All too common. There WAS a reinforcing kit from Toro, but is now NLA. Make your own.
Reinforcing goes on the opposite side, not between frame & Unidrive. Pictures of my C81 with plate and diagonal braces...
Edited by ri702bill
  • Like 5
  • Excellent 3
ebinmaine
Once you've repaired it properly and added some beef it'll likely never move again.
Remember to grind the rust out of those cracks if you intend to weld into them.
Do feel free to post pics of your repair.
It's great to see someone fixing building maintaining instead of scrapping.
  • Like 4
ri702bill
Because - once it's gone, it's gone for good. Evenn a busted up roller can become repurposed "Yard Art"
  • Like 7
Cracks are welded on both sides . Mating surface ground flat . I might come up with a way to reinforce it but I had to get the trany back on so I can move it . Next we have to weld the cracks on the dash tower . The Tractor is 57 years old and will have many more years left in it.
  • Like 6
Lee1977
I used two 1 1/2" x 1/4" ground on the back side to fit between those ridges. Then added 1 1/2" x 1/4" braces.. You don't have to take the tractor apart to do it this way.
Edited by Lee1977
  • Like 4
  • Excellent 3
I Think I will do this .
