JRP
Just a tire question
JRP
Hi everyone.   I  have a 520h that I need to replace  the front  tires as they are pretty  worn.  It currently  has  16 x 7.50 x 8 tires.  Are there  any negatives to the tractor performance by replacing  them with 16 x 6.50 x 8 tires, which seem generally  less expensive and more  readily  available?
8ntruck
Part of the answer depends on how you are using your 520h.  If you have a snow blower, plow, front end loader, or a tiller, smaller tires probably are not a good idea.  If you are using it mostly to mow and pull a garden cart around, the smaller tires won't hurt.
kpinnc
I can show you a direct comparison. The first pic is a 16x6.50-8, the second are 7.50-8 on the same wheel.
Apart from the wheel weight, there's not much difference. Side by side you really can't tell. Back when tires actually measured what they claimed to be, it might have been a bigger difference. Now the 7.50 tires are only about 1/4 inch wider each side.
Edited by kpinnc
JRP
Thanks  so  much for  your  replies, everyone.   That info is useful.  I  primarily  use my tractor for plowing  and hauling.   Not any mowing.
Lee1977
I have 18 x 650 x 8 on my 520 and 24 x 950 x 12 on the rear makes it a bit tighter installing the deck.
