bkarp@roadrunner.com 6 #1 Posted October 27, 2023 my 310-8 all of a sudden does not engage the transmission in any gear. Drive belt is ok and adjusted,no difference in high or low range. With engine off and transmission in any gear you can still push the tractor with no resistance.any ideas,hopefully not a transmission rebuild. Share this post Link to post Share on other sites
gt14rider 843 #2 Posted October 27, 2023 Check keyway at wheel hub to axle, transmission drive pulley to input shaft. Take a marker, put a line across hub across axle, try to move it and see if the line moved 2 1 Share this post Link to post Share on other sites
John c 86 #3 Posted October 27, 2023 is the hi-lo range selector handle fully engaged, 1 Share this post Link to post Share on other sites
wallfish 17,506 #4 Posted October 27, 2023 Forcing the high low shifter into gears or bumping it hard by accident like getting on and off can break the shift fork inside the trans that slides the gears back and forth and leave it stuck in a neutral position. Best if you can give ALL of the circumstances and symptoms that occurred before this happened, any funny noises? Acting up over time? The more info you can provide the better an internet diagnosis is. Otherwise it's pretty much guessing. 1 Share this post Link to post Share on other sites
bkarp@roadrunner.com 6 #5 Posted October 27, 2023 to gt14ider thanks for the tip the key was missing and the pulley was half off the shaft fixed it in ten minutes. thanks again for the help. Brent 1 2 1 Share this post Link to post Share on other sites
