Decisions Decisions...
By
Cee245, in Restorations, Modifications, & Customizations
Similar Content
By Bill D
I used these three pieces of plastic pipe to make a replacement steering column cover for two my tractors. Worked great. Cut one end at about a 47 degree angle. Anyone else try this? Bill
By GEnd
Hi all,
New to the group and hoping to tap into your knowledge. Also hoping I'm posting in the right place. Please excuse me if not.
I live in NE Minnesota, and am looking for a WH tractor for mowing and snowblowing.
I have a couple of questions I'd like your opinion/knowledge on, mostly about snow blowers and steering:
Did all 520H/C models after 1991 have gear reduction steering? How do I know if a machine has gear reduction or not?
Do the newer xi series have gear reduction? I think the 520/2/3xi offered power steering as an option, but do non-power steering models incorporate gear reduction?
I'm leaning toward 2 stage blower, just because it seems heavier duty, and it snows a ton in NE MN. Are the 2 stage units worthwhile?
I was lucky enough to work for Toro for a few years, and really want to find a red machine. Lots of green around here, but hoping to stay RED. Thanks for your help.
Greg
By jmdavidh09
Has anyone converted a 520-8 over to gear reduction steering?
Some questions if you have:
1. Does the motor have to come out?
2. Since the 520-8 has a swept axle, do I just need the lower steering shaft and gear box out of the donor?
3. Anything I am missing or should this be a simple swap?
Thanks in advance!
