hotajax
Carb Adjustment Question K321 Engine 14 HP Kohler
hotajax
If tractor is idling, and I go from idle to full speed with the throttle, and get a small puff of smoke, which screw do I adjust?  The idle screw or the high speed screw?   It also smells a bit rich while I'm cutting, so I probably need to lean that one out.   Thanks
ri702bill
Getting the "transition" from idle to main jets can be a challenge some times. On a fully up-to-temp engine - engine "off", refer to the Kohler manual - close to idle screw GENTLY, back it out the recommended number of turns. Do the same for the main. Start the engine - check the idle RPM. close the idle screw 1/8 turn at a time until the rpm drops, go back to where you were, noting the number of turns - do the same backing it out, rpm MAY rise - that is good - continue until it starts to fall. Go back to the highest idle rpm. Throttle up from idle. Did it go smoothly or stumble?? Do the high speed screw next - same procedure. You May have to richen the mix on the idle to "fix" a stumble.
Short version - OK to go a bit rich on the idle circuit to get a good transition - you do no "Work" at that speed. Get the best rpm and throttle response at the high rpm work range - do NOT go lean!!!
Wheelhorse#1
Also check to make sure the choke is adjusted properly.Sounds dumb but I a had a running rich issue and I somehow overlooked the choke/ butterfly slightly in closed position .
Sometimes the small things can easily get over looked.
  • Like 4
hotajax
Thanks, Good write up.  Where in RI are you?  I spent ALL of my RI time in Newport.  Avoiding the brig after a night out.
ineedanother
True. And you might want to give a good quality new spark plug a try as well before you're chasing the wrong issue.
ri702bill
West Bay - the mainland. Actually, my town is the geographic center of RI.
I avoid "Zooport" - too many ripoff restaurants and maroons. Team that up with beach traffic - not for me....
953 nut
Here is information from the Kohler manual.Rich is betern than lene. If the mixture is too lene an engine will overheat.
hotajax
Gotta go where the Navy sends ya
  • Haha 2
hotajax
Thanks for the tips on setting the carb.  The diagram from @953 nut and @ri702bill was priceless.  Richened up the low end, and it idles sweet.  No more pops.  Thanks again, gents.
hotajax
Of course I don't think it hurts that my tractor is now running on non-ethanol gas.
