hotajax 223 #1 Posted October 24, 2023 (edited) Are those things a replaceable part? Tractor is a 314-8. They are split almost all the way in half, and it won't be long. Thanks. I don't even know if they are called "toggles" Probably some other name. If you know the correct name so I can do a search, I'm down for it. Thanks again. Edited October 24, 2023 by hotajax 1 Share this post Link to post Share on other sites
ri702bill 8,326 #2 Posted October 24, 2023 I may be wrong, but check with McMaster Carr......... 1 Share this post Link to post Share on other sites
lynnmor 7,307 #3 Posted October 24, 2023 (edited) See if you can still buy from this company. I see they have online shopping now. Edited October 24, 2023 by lynnmor 3 1 Share this post Link to post Share on other sites
Handy Don 12,232 #4 Posted October 24, 2023 Be ready. The material in the some newer toggle hold-down’s I bought is not as flexible/stretchy as the original WH ones. Hence the mount positioning and length must be carefully considered. 1 Share this post Link to post Share on other sites
hotajax 223 #5 Posted October 24, 2023 1 hour ago, lynnmor said: See if you can still buy from this company. I see they have online shopping now. That Actos company had oodles of them. Thanks. Share this post Link to post Share on other sites
hotajax 223 #6 Posted October 24, 2023 (edited) 2 hours ago, ri702bill said: I may be wrong, but check with McMaster Carr......... @ri702bill: I checked with McMaster, they have them, too. That place has the greatest selection of gadgets in the galaxy. I bet you could buy stuff there that would keep even your mother-in-law happy. Edited October 24, 2023 by hotajax 2 Share this post Link to post Share on other sites
hotajax 223 #7 Posted October 24, 2023 (edited) Do I have to drill out the old rivets, then get a rivet gun? Is that how those toggles are replaced? Thanks. Edited October 24, 2023 by hotajax Share this post Link to post Share on other sites
ri702bill 8,326 #8 Posted October 24, 2023 29 minutes ago, hotajax said: @ri702bill: I checked with McMaster, they have them, too. That place has the greatest selection of gadgets in the galaxy. I bet you could buy stuff there that would keep even your mother-in-law happy. I swear that rhey bought the "AJAX" company in the Road Runner cartoons and expanded..... 1 Share this post Link to post Share on other sites
8ntruck 7,007 #9 Posted October 24, 2023 These might still be available from a Toro dealer. I was on the Toro master parts web site a while ago, and I seem to remember them as still being an active part number. Disclaimer - I'm working from memory here - and that is not as reliable as it used to be. Share this post Link to post Share on other sites
ineedanother 1,369 #10 Posted October 24, 2023 3 hours ago, hotajax said: Are those things a replaceable part? Tractor is a 314-8. They are split almost all the way in half, and it won't be long. Thanks. I don't even know if they are called "toggles" Probably some other name. If you know the correct name so I can do a search, I'm down for it. Thanks again. I think I've replaced all of mine by now... https://wheelhorsepartsandmore.com/product/106825-assy-flex-draw-latch-for-wheel-horse/ Share this post Link to post Share on other sites
JCM 9,168 #11 Posted October 25, 2023 9 hours ago, hotajax said: Do I have to drill out the old rivets, then get a rivet gun? Is that how those toggles are replaced? Thanks. Yes, if you want to replace the latch as well. Toro dealers have them as well as Parts tree . # 106825 Handle and Latch. rivets not included. 1 Share this post Link to post Share on other sites
Achto 27,587 #12 Posted October 25, 2023 14 hours ago, hotajax said: Are those things a replaceable part? https://wheelhorsepartsandmore.com/product/106825-assy-flex-draw-latch-for-wheel-horse/ Share this post Link to post Share on other sites
hotajax 223 #13 Posted October 25, 2023 6 hours ago, JCM said: Yes, if you want to replace the latch as well. Toro dealers have them as well as Parts tree . # 106825 Handle and Latch. rivets not included. @JCM The latches seem to be solidly mounted. It looks like you can disassemble the old assembly and replace just the rubber part. Thanks for responding Share this post Link to post Share on other sites
JCM 9,168 #14 Posted October 25, 2023 Yes you can. Small cotter and pin removal to replace just the rubber. @hotajax Share this post Link to post Share on other sites
hotajax 223 #15 Posted July 29 On 10/25/2023 at 6:12 AM, Achto said: https://wheelhorsepartsandmore.com/product/106825-assy-flex-draw-latch-for-wheel-horse/ Achto: The rubber latches that are on there now do not have the cotter pin ass'y, and from what I can see the rivets have to come out to get off the old latches. What is the best way to remove the rivets? It looks like they are attached from the inside, and "big head" on the rivet is on the outside of the tractor. Thanks gents. ' Share this post Link to post Share on other sites
Achto 27,587 #16 Posted July 29 35 minutes ago, hotajax said: What is the best way to remove the rivets? One method would be to grind the inside of them smooth & then punch them out. You can also drill them out if you can find a good center on them. 1 Share this post Link to post Share on other sites
Handy Don 12,232 #17 Posted July 29 FWIW, I tried ordering some of these from the jungle site. They were solidly made, and the ones I got had stainless hardware, but the “rubber” did not have even as much elasticity as the ones I’d be replacing! Share this post Link to post Share on other sites
c-series don 8,708 #18 Posted July 29 I recently got them from Brian at K+B Wheel Horse Parts. They have the removable pin so you can just replace the rubber part. 2 Share this post Link to post Share on other sites
hotajax 223 #19 Posted July 29 (edited) 4 hours ago, Achto said: One method would be to grind the inside of them smooth & then punch them out. You can also drill them out if you can find a good center on them. I was not crazy about grinding off the end caps. It looks like the only way Thanks for helping out Edited July 29 by hotajax Share this post Link to post Share on other sites
WHX?? 48,821 #20 Posted July 29 1/8 inch drill and go careful on the rivets. 1 Share this post Link to post Share on other sites
lynnmor 7,307 #21 Posted July 30 1 hour ago, WHX?? said: 1/8 inch drill and go careful on the rivets. If the rivets are 1/8” I would use a drill that is a bit larger so that it will cut the head off without entering the part. Just stop when the head is coming free. 1 Share this post Link to post Share on other sites
Handy Don 12,232 #22 Posted July 30 12 hours ago, lynnmor said: If the rivets are 1/8” I would use a drill that is a bit larger so that it will cut the head off without entering the part. Just stop when the head is coming free. Also, this is a good time to break out a sharp drill bit and go slow. Share this post Link to post Share on other sites
