wh315-8
Two more shows down
Pullstart
Awesome update, you said you’d be showing it a bunch this year!  If anyone recalls, this was the raffle RJ from the Big Show!
  • Thanks 2
wh315-8
Yes this is the one. After a few minor issues, she runs like new. I had to come up with some weight on the front to keep her from Rearing Up. I had a dozer mount I put on and built a simple wooden box with the bricks. A lot of people thought it was a cute idea. Added about 25# but it was enough to Tame Her. T shirts & hoodies are available on wheelhorseclub.com
  • Excellent 1
  • Similar Content
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • Traveller28
      By Traveller28
      I wanted to jump on here and show y'all my lastest project. A 1960's model 704(mainly, other parts are used that aren't 704) i decided to try what I've wanted to do for a while. I had a bunch of parts lying around from other builds I've done and decided to pull out the frame and hood from the last 704 I built and start putting together my tricycle gear tractor.
    • wh315-8
      By wh315-8
      Curious what aftermarket options has anyone done to add the 3 point to the C195?
      Seems that the JD 317 style could be a bolt on to the C195s uprights. Some other brands seem similar that might bolt on with some minor modifications. Otherwise I know the D series is a similar setup other than the upper arm and the center point bracket, but it looks to be a fairly simple design to build.
      MF 1855 looks close to WH design.
      Case 446 design almost looks identical setup.
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
