Little Help 417-8 Tie Rod part number ? Need set ~
By
rustyedge1, in Wheel Horse Tractors
Similar Content
By Ifixoldjunk
So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
Like would generic adjustable go-kart tie rods do the trick?
By 417Horse
I've got a 48" dozer blade hooked up to my 417-8 and my driveway is 450 ft of asphalt. i'd like opinions on what type of skid shoes would work best on the pavement? I've had the blade for years now and have flipped over the flat bar edge to use the good side. The blade has the has the mounting holes for the shoes, but I'm just wanting opinions on what would work best in my situation. The factory shoes are a little on the expensive side, but if I get good opi nions about using those, I might go that route.
By Elijah’s Wheel Horse 417A
Hello all, I recently inherited a Wheel Horse 417-A from my Late Grand-Father. It has been leaking from the Oil Pressure Sensor and I can’t seem to find this particular sensor anywhere If you could give me some leads that would be great! The engine is a KT17 Series II it smokes right under the muffler coming from the sensor i would like to fix it as it has the mowing deck, 2 Tillers, snow plow/dozer, snow blower, and 2 cabs this tractor is very centimental to me and it runs amazing other than this little part!! Also if you could provide any information on this particular model that would be great! Thanks!
By The Gman
A short vid of my 312/417 in infrared. It's a FLIR one. Uses a smart phone, I have an old Note2. After looking at it I did notice the rear cylinder exhaust seemed to be running cooler. It will even show what wires are drawing more current and heating up
Enjoy????
flir_20180123T111311.mp4
By 417Horse
I have a 417-8 Horse that dropped a tie rod today. The Wheel Horse parts manual calls for a #102592 for the RH rod and a #102593 for the LH rod. What is the newer (Toro) part #? Also, from the pictures I've seen, the newer tie rod is fully adjustable. If that is the case, am I correct in thinking that only one part number is needed for both sides? - Thanks
