ebinmaine 67,415 #101 Posted November 21, 2023 11 minutes ago, ebinmaine said: In other news..... I'll be wiring tomorrow. I'll post pics when I can but I have questions. Non stock system so I can't just follow a schematic diagram. Here's a picture of the back of the switch. I know we touched on this earlier but I'm still confused as to what G and M terminals should be connected to. 1 Share this post Link to post Share on other sites
Horse Newbie 7,067 #102 Posted November 21, 2023 2 minutes ago, ebinmaine said: 6 minutes ago, Horse Newbie said: Do you need a picture of that piece ? If I could get a picture or measurements or both that would be awesome. I'm hoping I can make something out of strap steel and a bolt maybe? I am traveling for Thanksgiving now. I will get those pics with measurements ASAP … 1 Share this post Link to post Share on other sites
Horse Newbie 7,067 #103 Posted November 21, 2023 1 minute ago, ebinmaine said: I know we touched on this earlier but I'm still confused as to what G and M terminals should be connected to Maybe G = ground, M = magneto… Wild guess…. 2 Share this post Link to post Share on other sites
ebinmaine 67,415 #104 Posted November 21, 2023 5 minutes ago, Horse Newbie said: Maybe G = ground, M = magneto… Wild guess…. My thoughts exactly ... But I don't remember the G being anywhere particular. 1 Share this post Link to post Share on other sites
ebinmaine 67,415 #105 Posted November 21, 2023 Trina and I were talking this over a few minutes ago about the wiring. We believe that the RED wire coming out from behind the flywheel was connected to the ammeter which was in turn connected directly to the solenoid so it was direct battery connection all the time. The switch has: G. Ground M. Magneto S. Solenoid B. Battery L. Lights We're pretty sure that B & L were NOT connected when we got the tractor. 1 Share this post Link to post Share on other sites
Horse Newbie 7,067 #106 Posted November 22, 2023 Just tossing this out there… any chance “S” stands for start ? But I guess not- that would probably be an “I” for Ignition , huh ? 1 Share this post Link to post Share on other sites
ebinmaine 67,415 #107 Posted November 22, 2023 3 minutes ago, Horse Newbie said: Just tossing this out there… any chance “S” stands for start ? It kinda could.... Still would have the same connection. 3 minutes ago, Horse Newbie said: But I guess not- that would probably be an “I” for Ignition , huh ? No "I" on this one. Never was.... But I don't know if this switch is from the Wheelhorse or the crapsmann. 1 Share this post Link to post Share on other sites
953 nut 55,182 #108 Posted November 22, 2023 2 hours ago, ebinmaine said: Here's a picture of the back of the switch. I know we touched on this earlier but I'm still confused as to what G and M terminals should be connected to. Do we know if this switch is in good condition? Best bet would be to buy a new 103-991 switch and use the Operator Manual wiring diagram. That way if a problem popped up later you could go directly back to the diagram. 2 Share this post Link to post Share on other sites
ebinmaine 67,415 #109 Posted November 22, 2023 41 minutes ago, 953 nut said: Do we know if this switch is in good condition? Best bet would be to buy a new 103-991 switch and use the Operator Manual wiring diagram. That way if a problem popped up later you could go directly back to the diagram This was a running tractor when we got it. I may very well have a 103991 here though. 2 Share this post Link to post Share on other sites
Moparfanforever 844 #110 Posted November 22, 2023 2 hours ago, ebinmaine said: Trina and I were talking this over a few minutes ago about the wiring. We believe that the RED wire coming out from behind the flywheel was connected to the ammeter which was in turn connected directly to the solenoid so it was direct battery connection all the time. The switch has: G. Ground M. Magneto S. Solenoid B. Battery L. Lights We're pretty sure that B & L were NOT connected when we got the tractor. Ground wire goes to a small screw like stud with a blade that the kill wire slides onto. Grounds the Mag to shut off the tractor. If you need one ,I will try to get a picture. Magneto.. wire goes to the Magneto (coil) Solenoid.. goes to the small post on the solenoid Battery.. goes to the positive battery cable on the solenoid Lights?? You sure the switch doesn't have ACC on it?? I forget how the charging wire and the Amp gauge is wired. I think I didn't put one on my GT1848. Battling a bad head cold at the moment and I don't remember. Don't really need a head cold for that, I have CRS most of the time!! 1 1 Share this post Link to post Share on other sites
ebinmaine 67,415 #111 Posted November 22, 2023 25 minutes ago, Moparfanforever said: Ground wire goes to a small screw like stud with a blade that the kill wire slides onto. Grounds the Mag to shut off the tractor. If you need one ,I will try to get a picture. Magneto.. wire goes to the Magneto (coil) Solenoid.. goes to the small post on the solenoid Excellent. 25 minutes ago, Moparfanforever said: Battery.. goes to the positive battery cable on the solenoid Lights?? You sure the switch doesn't have ACC on it?? Nope. 3 positions. Off. Run. Start. Likely I'll leave these two disconnected for now. 25 minutes ago, Moparfanforever said: I forget how the charging wire and the Amp gauge is wired. I think I didn't put one on my GT1848. I'll be leaving the amp gauge OUT of this tractor. 25 minutes ago, Moparfanforever said: Battling a bad head cold at the moment and I don't remember. Feel better soon!! 25 minutes ago, Moparfanforever said: Don't really need a head cold for that, I have CRS most of the time!! Yyyeeeaaahhh. Me too man. Me too. 1 Share this post Link to post Share on other sites
Horse Newbie 7,067 #112 Posted November 22, 2023 2 minutes ago, ebinmaine said: Run Isn’t “ACC” on on RUN ? 1 Share this post Link to post Share on other sites
ebinmaine 67,415 #113 Posted November 22, 2023 5 minutes ago, Horse Newbie said: Isn’t “ACC” on on RUN ? On this switch it would be, yes. 1 Share this post Link to post Share on other sites
kpinnc 12,002 #114 Posted November 22, 2023 4 hours ago, ebinmaine said: But I don't remember the G being anywhere particular. The tab marked "G" is strapped to the case. That is always the ground. 2 Share this post Link to post Share on other sites
Moparfanforever 844 #115 Posted November 22, 2023 Hope you can make this out. The shiny part is a screw stud that has a wire blade style that the ground wire goes to. I wouldn't think you would necessarily have to use the stud for a ground, I would think any ground would work. I put an M8 on an older Charger and run the ground wire to a nut/bolt on the tractor and it works. 1 1 Share this post Link to post Share on other sites
Moparfanforever 844 #116 Posted November 22, 2023 When I say ACC,I mean on the back of the switch. 2 Share this post Link to post Share on other sites
ebinmaine 67,415 #117 Posted November 22, 2023 1 hour ago, Moparfanforever said: Hope you can make this out. The shiny part is a screw stud that has a wire blade style that the ground wire goes to. I wouldn't think you would necessarily have to use the stud for a ground, I WOULD THINK ANY GROUND WOULD WORK. My thought too. This is perfect. Thank you. 1 Share this post Link to post Share on other sites
kpinnc 12,002 #118 Posted November 22, 2023 13 hours ago, ebinmaine said: This was a running tractor when we got it. I may very well have a 103991 here though. On an older switch at least, that ground strap is a dead giveaway to what type ignition it is intended for. The older coil ignition type won't have a ground. You guys are really moving on this resto! 2 Share this post Link to post Share on other sites
ebinmaine 67,415 #119 Posted November 22, 2023 3 minutes ago, kpinnc said: On an older switch at least, that ground strap is a dead giveaway to what type ignition it is intended for. The older coil ignition type won't have a ground. Yepp. That's the reason I refuse to use (or recommend) aftermarket switches that aren't marked. I've seen a few. IMHO an unmarked switch is absolute garbage. 3 minutes ago, kpinnc said: You guys are really moving on this resto! We're getting there! Won't be as much progress as I was figuring today because we got more snow than forecast. Seat time on The Military Tribute Tractor "Millie" for Trina!! Gotta get it set up first. 1 Share this post Link to post Share on other sites
kpinnc 12,002 #120 Posted November 22, 2023 11 minutes ago, ebinmaine said: I've seen a few. IMHO an unmarked switch is absolute garbage. Agreed. I've seen a few "new" switches that at least appear to work with either type ignition, and they will make you burn stuff up if you try to use the factory plug. 2 Share this post Link to post Share on other sites
kpinnc 12,002 #121 Posted November 22, 2023 13 minutes ago, ebinmaine said: we got more snow Wow, already? All we got is rain, but that's normal here. Forgive the hijack. I'm just shocked you guys have snow this early. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,415 #122 Posted November 22, 2023 22 minutes ago, kpinnc said: Wow, already? All we got is rain, but that's normal here. Forgive the hijack. I'm just shocked you guys have snow this early. Already?? Early??? Oh boy. Oh boy. Oh boy. Oh boy. Oh boy. Oh boy. Oh boy. Son we needs to talk. Today is November 22nd. This is near to THE LATEST day in the year we've had the first measurable snow (we've seen flurries several times). Our growing season is ended by the first frost usually in mid September. We normally get a measurable snow sometime in October. Occasionally late September. The last 20 years things have been changing. Maine is the state that is warming the fastest of the lower 48. Our weather is not what it once was. But the winters are still pretty aggressive. 1 1 Share this post Link to post Share on other sites
kpinnc 12,002 #123 Posted November 22, 2023 4 hours ago, ebinmaine said: Son we needs to talk. Today is November 22nd. If and I do mean IF we get any significant snow, it's usually early spring stuff. I've had one white Christmas in my 53 years. A couple more near misses. Last year was pretty cold for us, with several single digit nights. Not unusual to have them, but last year we had quite a few by comparison. 2 Share this post Link to post Share on other sites
Horse Newbie 7,067 #124 Posted November 22, 2023 1 hour ago, kpinnc said: Last year was pretty cold for us, with several single digit nights Climate change/ Global warming…😆 2 Share this post Link to post Share on other sites
ebinmaine 67,415 #125 Posted November 22, 2023 Back on all fours. Engine turns over!! Needs minor finishing up and hood put on. Hopefully add gas and drive it around!! 3 7 Share this post Link to post Share on other sites
