Bill D 1,932 #1 Posted October 15, 2023 Trying to free up this bushing on a hydro linkage I bought. Heating and soaking isn't working. Any ideas? Thanks. 1 Share this post Link to post Share on other sites
Herder 2,354 #2 Posted October 15, 2023 Repeat process until I see if I have one, I will check and let you know. Share this post Link to post Share on other sites
peter lena 8,716 #3 Posted October 15, 2023 @Bill D how about some KROIL . plastic hammer ? once that Kroil gets in there , might try a small pipe wrench , think , heat and Kroil will do it , worked on anything that was solid for me . Pete Share this post Link to post Share on other sites
Ed Kennell 38,598 #4 Posted October 15, 2023 Freeze it then quickly heat the OD surface. 3 Share this post Link to post Share on other sites
Bill D 1,932 #5 Posted October 15, 2023 4 hours ago, Herder said: Repeat process until I see if I have one, I will check and let you know. Thank you sir. Share this post Link to post Share on other sites
Herder 2,354 #6 Posted October 15, 2023 3 hours ago, Bill D said: Thank you sir. I have a hydro assembly out of a C series, the outside edge needs to be bent back a little. You can have it, I also have some that are still in place, if you need other items and what to remove them. One's a Charger and anther C series. Share this post Link to post Share on other sites
Bill D 1,932 #7 Posted October 15, 2023 4 hours ago, Herder said: I have a hydro assembly out of a C series, the outside edge needs to be bent back a little. You can have it, I also have some that are still in place, if you need other items and what to remove them. One's a Charger and anther C series. Thank you. I'll be in touch. Share this post Link to post Share on other sites
