Similar Content
By rwlvt
Hi folks,
I tried to help a friend with a Toro 520H that won't start.
https://photos.app.goo.gl/19fPX79LGMPCBcnB6
(Attempting to insert a photo by URL doesn't seem to be working.)
Here are some identifiers for the engine:
Engine Model: P220G-I/109556
P/N941811
S/N: A973636148
I went through the usual--checking for spark. I'm getting spark in both cylinders. So, i'm looking at gas. There is a fuel pump on the side of the engine.
https://photos.app.goo.gl/RY4hHAfLLGeyCBaS8
I pulled the gas line below it and am getting gas from the tank. I pulled the line above it and cranked the engine. I wasn't getting anything! So, I assumed it was a bad fuel pump. I ordered and installed a new fuel pump, but still no luck. This is a vacuum actuated pump, so I pulled the pump and stuck my thumb over the tube while I cranked the engine. I expected to get either a vacuum or compression. I got neither. Any thoughts about where I go from here?
Thanks in advance,
Ron
By Jon Paulsen
Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
By morePEdal
416-8 with Onan P216 Engine
The good:
*576 hours
*Nice, clean deck (42”)
*Nice Plow
*Wheel Weights
*Chains
*2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
*Original receipts and paperwork and manuals.
*Receipt showing tune-up and changing from the deck to the plow in November 2021
The bad:
*The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
*Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
*I didn’t get a chance to test drive it because of this.
*One front tire goes flat fast, one rear tire has a slow leak.
*He is going to buy a battery before I look at it again on Friday so I can test drive it.
What do you think is the issue? Is it the battery or fuel system?
Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
*He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
He’s asking $500.
By t_furl43
A really nice 1995 wheelhorse 416H runs and drives great no leaks only 920 hrs, motor runs strong, starts right up, brand new back tires 23x10.5x12, has slot hitch, comes with 42” RD deck and 42” snowplow, wheel weights and all 4 hubcaps, I’ll also throw in an extra set of tires, will need a seat but that’s it, pickup in millersville pa 17551, price is negotiable, will trade for an Economy Powerking tractor or John Deere 318
By Tim Ziethen
Does anyone know what is required to swap out the Onan engine with broken rod on my 516H and drop in an good working engine from my 310-8 parts tractor? I have read all the posts I can find but the ignition and charging circuit and wiring compatibility is not clear. Thanks for the help!
