dr.mac
cranks but no spark until letting of switch
dr.mac
I am sure I have read about this on Red Square but of course cant find it when I need it.   1966 10hp Kohler W.H.  engine cranks fine and only produces spark when I let off the switch.
Thank all you guys in advance.  dr.mac
Pullstart
:text-welcomeconfetti:  Have you recently replaced the ignition switch?  There may be a short in your original, or you procured the wrong replacement…
  • Like 3
Handy Don
Use the search bar on the upper right of this page to look for the manual.
Key in “tractor 1966 nnn” where nnn = your model number
Search in Files or Documents
Be sure to check the “use all my search terms” option.
OM = owner's manual
IPL = illustrated parts list
Wiring = wiring diagram included
ranger
Sometimes if your battery is a bit low on charge, you have some bad electrical connections, a failing coil, starter motor etc, the starter whilst turning causes a voltage drop in the ignition circuit which can result in a weak, or no spark. On releasing the key, the coil ‘sees’ a higher voltage and produces a spark good enough to fire the charge in the cylinder.
Edited by ranger
  • Like 3
