gwood 16 #1 Posted October 10, 2023 16-38 HXL Toro Wheel Horse with grass catcher question: Is there a need to coat the inside of the chute and bagger Elbow or better to leave it as sent? Share this post Link to post Share on other sites
peter lena 8,681 #2 Posted October 10, 2023 @gwood grass catchers are silently begging for a clean out , and any help on discharge flow , decks regularly , fail / rot out , due to poor discharge , personally like 303 vinyl boat cleaner on plastic , brings back color , enhances the finish slick / smooth state . that's what you want , would also drop and look at the underside of the dock , a clean out and a hot sun lubrication soak would also be nice , pete 1 1 Share this post Link to post Share on other sites
gwood 16 #3 Posted October 10, 2023 3 hours ago, peter lena said: @gwood grass catchers are silently begging for a clean out , and any help on discharge flow , decks regularly , fail / rot out , due to poor discharge , finish slick / smpersonally like 303 vinyl boat cleaner on plastic , brings back color , enhances theooth state . that's what you want , would also drop and look at the underside of the dock , a clean out and a hot sun lubrication soak would also be nice , pete Thanks for that information Pete! 1 1 Share this post Link to post Share on other sites
peter lena 8,681 #4 Posted November 1, 2023 @gwood thanks for the reply , regular for me on any issue , is to stop / change / correct / what has been going on , make sense ? no matter what , the constant moldy / rot , under a deck , has got to be stopped , changed . any time I can drop a deck , prop it up to the sun , for hot drying effect , clean out , lubrication soak , fine file , blade touch up , I am there . having done that for years , it just does the job, also store decks , in a clean / oil soak mode over winter , upside down , angled up to wall . months of drying / oil retention , completely stops the grunge , like a screw in EYE BOLT to wall , with a heavy spring , hook , to hold deck . make a repetitive trouble spot , a solid no problem zone . you have to change something , in that fail zone . this is not in the book , but its looking you in the face . help out ? this freaks out a purest , regular , thought for me , over the fence , pete Share this post Link to post Share on other sites
