gwood
Grass catcher
gwood
16-38 HXL Toro Wheel Horse with grass catcher question: Is there a need to coat the inside of the chute and bagger Elbow or better to leave it as sent?
peter lena
@gwood  grass catchers are silently begging for a clean out , and any help on discharge flow , decks regularly , fail / rot out , due to poor discharge , personally like 303 vinyl boat  cleaner on  plastic , brings back color , enhances the finish slick / smooth state . that's what you want , would also drop and look at the underside of the dock , a clean out and a hot sun lubrication soak would also be nice , pete
  • Excellent 1
gwood
3 hours ago, peter lena said:
@gwood  grass catchers are silently begging for a clean out , and any help on discharge flow , decks regularly , fail / rot out , due to poor discharge , finish slick / smpersonally like 303 vinyl boat  cleaner on  plastic , brings back color , enhances theooth state . that's what you want , would also drop and look at the underside of the dock , a clean out and a hot sun lubrication soak would also be nice , pete
Thanks for that information Pete!
  • Thanks 1
peter lena
@gwood  thanks for the reply , regular for me on any issue , is to stop / change / correct / what has been going on , make sense ?  no matter what , the constant moldy / rot , under a deck , has got to be stopped , changed . any time I  can drop a deck , prop it up to the sun , for hot drying effect , clean out , lubrication soak , fine file , blade touch up , I am there . having done that for years , it just does the job, also store decks , in a clean /  oil soak mode over winter , upside down , angled up to wall . months of drying / oil  retention , completely stops the grunge , like a screw in EYE BOLT  to wall , with a heavy spring , hook , to hold deck . make a  repetitive trouble spot , a solid no problem zone . you have to change something , in that fail zone . this is not in the book , but its looking you in the face .  help out ?  this freaks out a purest , regular , thought for me ,  over the fence , pete
