grinchsr 634 #1 Posted October 9, 2023 Does anyone make a bolt on bracket to replace the front one on my deck? I checked on our vendors with no luck. I said bolt on because I do not own a welder. Another question has anyone cut with a deck minus the center roller? 1 Share this post Link to post Share on other sites
8ntruck 7,217 #2 Posted October 9, 2023 If your yard is flat enough, you should be ok mowing without the anti scalp roller. It usually does not touch the ground while mowing. If your lawn is lumpy, or if you need to drive over small rises to get onto the lawn, you are going to need that roller. 1 Share this post Link to post Share on other sites
CCW 1,310 #3 Posted October 9, 2023 If you cannot find one then a couple of pieces of 2x2 angle iron could be bolted on. Then would just need a bit of fabrication work to get over the rolled edge of the deck. 1 Share this post Link to post Share on other sites
SylvanLakeWH 26,304 #4 Posted October 9, 2023 I'd bend it straight, put the L bracket on outside of each side, make a sandwich with the original bracket kept on so to speak, line up the holes and bolt L to the deck... 3 Share this post Link to post Share on other sites
grinchsr 634 #5 Posted October 10, 2023 Thanks for the ideas. Share this post Link to post Share on other sites
Bill D 2,037 #6 Posted October 11, 2023 Wish you were closer. I'd weld that up for you Share this post Link to post Share on other sites
stevebo-(Moderator) 8,364 #7 Posted October 11, 2023 I am no great welder Ray but I could help you with that. 1 Share this post Link to post Share on other sites
grinchsr 634 #8 Posted October 11, 2023 Thanks for the offers Bill and Steve. I am going to try to run with out it for now my yard is not all that bumpy. I think it is beyond welding at this point anyway. I picked this deck up for a $100 and a seat. It is amazing what people can do to a deck Share this post Link to post Share on other sites
Rick3478 429 #9 Posted October 11, 2023 On 10/8/2023 at 10:12 PM, grinchsr said: Does anyone make a bolt on bracket to replace the front one on my deck? I checked on our vendors with no luck. I said bolt on because I do not own a welder. Another question has anyone cut with a deck minus the center roller? It's ugly, but still has some steel where it's needed. I think I'd straighten it up with a big crescent wrench, hammer, and body block and shove some washers alongside the roller so the rough rusty areas don't tear it up. I don't see the axle or roller in any of the photos, so don't know what they look like but can be re-used or replaced as needed. 1 Share this post Link to post Share on other sites
