SID 0 #1 Posted August 17, 2009 NEED HELP ON REINSTALLING REAR AXLE ASSEMBLY OF 310-8 Share this post Link to post Share on other sites
WHC-125 4 #2 Posted August 17, 2009 Are you talking about the axle or the transmission? :thumbs2: Share this post Link to post Share on other sites
SID 0 #3 Posted August 17, 2009 the whole assembly, we had to put a new fork in it for a friend and need some assembly diagrams to put the assembly back on the tractor Share this post Link to post Share on other sites
kpinnc 13,443 #4 Posted August 17, 2009 Go to the Master Parts viewer at Toro.com, enter the part number of your tractor (under the seat most likely- something like 01-10K804), and select the "manuals" tab. There will be a manual called the "Mechanical transmission manual" available for download. It's about 70 pages, but has all the pictures you need for ANY manual tranny work. Kevin Share this post Link to post Share on other sites
Duff 206 #5 Posted August 17, 2009 Go to the Master Parts viewer at Toro.com, enter the part number of your tractor (under the seat most likely- something like 01-10K804), and select the "manuals" tab. There will be a manual called the "Mechanical transmission manual" available for download. It's about 70 pages, but has all the pictures you need for ANY manual tranny work. Kevin Kevin's right, but be sure you print it out on the highest quality printer (or resolution) you can get access to. The photos are very helpful - if you can see them! If you've already got the tranny reassembled and are just looking to reattach it to the tractor, that process is pretty straightforward. Good luck! Duff :thumbs2: Share this post Link to post Share on other sites
