CasualObserver 3,408 #26 Posted October 5, 2023 Ditto Those would be my two choices from there as well. (and swap the knobby tire off that one round hood back onto the 1045 where it belongs.) 4 1 Share this post Link to post Share on other sites
Pullstart 62,913 #27 Posted October 5, 2023 @BairleaFarm where are all these located again? 2 Share this post Link to post Share on other sites
OoPEZoO 525 #28 Posted October 5, 2023 Vultures are circling....... 2 Share this post Link to post Share on other sites
BairleaFarm 340 #29 Posted October 5, 2023 40 minutes ago, Pullstart said: @BairleaFarm where are all these located again? Just now, OoPEZoO said: Vultures are circling....... As usual. Ill update location after I look at them 2 3 Share this post Link to post Share on other sites
BairleaFarm 340 #30 Posted October 5, 2023 Unfortunately the 701 had a locked up rear end. The other round noses were really rough. I got the 1045 rear freed up enough to get it loaded and it was the only real roller. After 10 years I'm finally able to say I own a Wheel Horse again. For a couple Benjis I'm happy. The sleeve hitch it rusted solid so hopefully the rear-end on this is OK. I'll start a post for it once I get it home. Thanks for the info guys. Here are a few pics I got of the others... 2 Share this post Link to post Share on other sites
BairleaFarm 340 #31 Posted October 5, 2023 6 hours ago, CasualObserver said: That alone is a $200 part if they have it. Check his hand. 1 3 Share this post Link to post Share on other sites
ebinmaine 67,633 #32 Posted October 5, 2023 57 minutes ago, BairleaFarm said: couple Benjis I'm happy You did just fiiiine for that. 58 minutes ago, BairleaFarm said: The sleeve hitch it rusted solid so hopefully the rear-end on this is OK. Definitely repairable. Just a matter of what needs doing. Share this post Link to post Share on other sites
rjg854 11,387 #33 Posted October 6, 2023 16 hours ago, BairleaFarm said: I got the 1045 Did you happen to get the drive belt cover? Or any other missing parts? 1 Share this post Link to post Share on other sites
BairleaFarm 340 #34 Posted October 6, 2023 6 minutes ago, rjg854 said: Did you happen to get the drive belt cover? Or any other missing parts? NO - what you see is what i get. Should be fun trying to find the drive belt cover. 1 Share this post Link to post Share on other sites
ebinmaine 67,633 #35 Posted October 6, 2023 4 minutes ago, BairleaFarm said: Should be fun trying to find the drive belt cover. You seem to have a decent base mechanical knowledge. Might be easier to make one. Several of us could give you proper measurements. Share this post Link to post Share on other sites
BairleaFarm 340 #36 Posted October 6, 2023 1 minute ago, ebinmaine said: Might be easier to make one. Several of us could give you proper measurements. I havent gotten that far as im not sure ill even be keeping this. Ill get it running and driving and go from there. I dont have a way to bend metal and make it look good. 1 Share this post Link to post Share on other sites
ebinmaine 67,633 #37 Posted October 6, 2023 2 minutes ago, BairleaFarm said: I havent gotten that far as im not sure ill even be keeping this. Ill get it running and driving and go from there. I dont have a way to bend metal and make it look good. Absolutely understandable. I'm sure you realize this already: Just remember that the belt GUARD is also the belt GUIDE. Don't try to shift into any gear while it's running without the guard. Share this post Link to post Share on other sites
