kpinnc
Tractor jack
Horse Newbie
23 minutes ago, kpinnc said:
I'm considering cutting the crank off and welding a 3/4 nut on the shaft so I can use a cordless drill to run it up and down.
You’ll void the warranty !:scared-eek:
  • Haha 7
Pullstart
Pretty nifty!  That’ll help get the trans oil over the hump!
SylvanLakeWH
:eusa-clap:
ri702bill
And to be able to properly grease the front axle......
IF you could add a curved "rocker" to the underside of the foot plate, it would keep the load more under the center as it lifts and tilts ....:twocents-02cents:
ebinmaine
Well done Sir.
Could you leave the crank in place and add the nut to the outside?
Perhaps both methods would be handy?
peter lena
@kpinnc  nice job on that , https://www.google.com/search?q=1%2F4"+grease+fitting+angle%2C+female&sca_esv=569708288&rlz=1C1CHBF_enUS866US866&sxsrf=AM9HkKkKsK4OZQjifs0lj , experiment with these , to make it easier to lubricate a tough spot , like steering column fan , maybe fun out , tube / hose , for quicker , lube up , Pete
Lee1977
I would not want that handle moving around with a drill turning it.
Edited by Lee1977
kpinnc
I was thinking of making the handle use a socket so it can reattach if needed.
  • Like 5
Horse Newbie
I would go with the 3/4” nut, void the warranty, and use a 3/4” combination wrench or ratchet and socket if you need to fine adjust the height…
  • Like 4
ebinmaine
Oh yeah you'd have to keep it slow for sure
clueless
you can find used Mojack Xl locally (Facebook) fairly cheap $200 or less, they will lift 750#  and are a bit more stable. I just remove the wheel stirrups and lift the front or rear of a tractor up to 24", also my go to jack for changing wheels or wheel bearing on all of my trailers, eezpeez and very stable.
kpinnc
I'll make a handle that slips over the nut for use when needed.
Yep, that's what I did. Runs to full length in about 15 seconds now.
Works well with the Scag too...
