Brockport Bill 1,825 #1 Posted September 25, 2023 the toro, and other part sites, list 3 mower deck belt part numbers for the 42" rear discharge mower deck (15-42rc01) --- part 1594 -- 6738 -- and 106125......... Which is the correct belt #, and what is the proper measurement length in inches for a correct 42" RD deck belt? Thanks - Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,247 #2 Posted September 25, 2023 Drive belt 108834 (1/2" x 98") Spindle belt 106125 (1/2" x 89.03") 1 Share this post Link to post Share on other sites
Brockport Bill 1,825 #3 Posted September 25, 2023 50 minutes ago, gwest_ca said: Drive belt 108834 (1/2" x 98") Spindle belt 106125 (1/2" x 89.03") many thanks!!!!!!!!! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,247 #4 Posted September 26, 2023 When you have belt numbers and not sure what they fit go to our empty SEARCH box and click on it. A drop down menu will appear and select Files. Enter a part number and see what shows up. 2 Share this post Link to post Share on other sites
Brockport Bill 1,825 #5 Posted September 26, 2023 4 hours ago, gwest_ca said: When you have belt numbers and not sure what they fit go to our empty SEARCH box and click on it. A drop down menu will appear and select Files. Enter a part number and see what shows up. thanks for the insights -- i am still learning to navagate the RSq site -- sometimes i find my way but other times its an adventure - - haha............ appreciate the pointers!! here's a web site i found a bit ago that i have used and is helpful to find the respective belt length for various belt part numbers ---- https://outdoorpowerinfo.com/belts/wheel_horse_belts.asp?fbclid=IwAR30E10elLLRa8PlrLjmGTcqSvqLUTNkx01uBu4Kp-fUgu5zy0AW0xHBZOM ---- one journey i still struggle with is if i have an unidentified belt and take the measurement, then how to cross reference back to a wheel horse part number to know what and where the belt is used, on what piece of equipment????????? hmmmm ?? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,247 #6 Posted September 26, 2023 In the back of these charts Wheel Horse has the belts listed by size. There will be some missing because of the chart age. Once you have the number search our files. The online ipl's are shared by similar models and the reason for multiple belts listed. An original ipl will show just the belts used for that model but we do not have original ipl's for all product. That is why I have tried to add the belts to each product list so the SEARCH will pick them out. 2 Share this post Link to post Share on other sites
peter lena 9,092 #7 Posted September 26, 2023 @Brockport Bill while you are in the area , would also check out the ROTATIONAL MOVEMENT EASE . like from the PTO , DRIVE TO THE MUEL DRIVE , does the belt move easily ? is it rough / held up in any way ? there are 10 related bearings , and lever linkage points . neighbors around me , must love the belt screaming engagement , of a deck drive , strangely , my horses do not do that . stay at it , pete Share this post Link to post Share on other sites
Brockport Bill 1,825 #8 Posted September 26, 2023 3 hours ago, peter lena said: @Brockport Bill while you are in the area , would also check out the ROTATIONAL MOVEMENT EASE . like from the PTO , DRIVE TO THE MUEL DRIVE , does the belt move easily ? is it rough / held up in any way ? there are 10 related bearings , and lever linkage points . neighbors around me , must love the belt screaming engagement , of a deck drive , strangely , my horses do not do that . stay at it , pete always study your insights Pete -- wonderful nuggets of info - thanks --- as an added note when i speak with other tractor owners i have shared what i have learned from your comments - - so you should be pleased to know your knowledge is spread far and wide -- Bill 1 Share this post Link to post Share on other sites
Bill D 2,094 #9 Posted September 26, 2023 On 9/25/2023 at 2:53 PM, gwest_ca said: Drive belt 108834 (1/2" x 98") Spindle belt 106125 (1/2" x 89.03") Now available at Lowe's! Share this post Link to post Share on other sites
