peter lena
go get it , rustproofing aerosol , get some now
peter lena
https://mytoolstore.com/products/aervoe-7045-h-d-open-gear-wire-rope-lube-16-oz?variant=17739792220260&currency=USD&utm_source=google&utm_medium=cpc&utm_campaign=google+shopping&gclid=CjwKCAjwsKqoBhBPEiwALrrqiKOh1sFqQ3GGiUe0fh3_36rkyG8o03sgWR-7_qq4tIgyGw4AOvVhpRoCIsgQAvD_BwE  , terrific price , would use a  penetrating oil first , as a carrier , creeper , then over spray with this , still have some in my stash , , this is a no brainer , only a suggestion , Pete
  • Like 3
peter lena
@Achto   also look around your area , might find it locally , pete
  • Thanks 1
peter lena
@Achto  if you have an industrial service center near you , that would be the place to find similar , you want something with a high stress rating , lubrication , as said , first a lighter quality , penetrating oil , to seep into seams / closed areas , then over spray , with heavier , so the lighter oil will carry the heavier into every area . done this for many years , on my cars , related . zero rust / rot , once it cures / dries , just inspect it when you service the  car / truck . bottom of door vents , fender well / to body seams . tail gate , next day verify the creep / protection , with a slight oil film in area . my son does this in Vermont , zero rust , wash my cars also , under spray , get the salt off of it . keep it oily , pete
  • Thanks 1
