gwood 16 #1 Posted September 16, 2023 Would like to know if any of you can tell me where I am to install a height spacer part #110932 on my 520H seat? 1) between the seat and forward/backward adjuster 2) between the adjuster and spring 3) between the spring and swivel plate Sure appreciate any help on this! Share this post Link to post Share on other sites
JCM 10,017 #2 Posted September 16, 2023 What year / model # 520-H . Part # 109989 nylon spacer goes between the seat and top of adjuster. 3 Share this post Link to post Share on other sites
gwood 16 #3 Posted September 25, 2023 My seat question maybe was not clear! I have 4 steel spacers about 3/4 " long ( part #110932 )that I believe need installed on 4 corners of the seat assembly to raise my seat. Here is my question: Have you installed these spacers on any of your tractors, and if so? 1) Should they go between the springs and swivel plate or 2) between the springs and the forward/ backward adjusters. The tractor I'm working on is a 520 H 20 HP Onan Performer 20 XSL engine Engine ID number 31- 200E01 15180 Wheel Horse Tractor Serial # 1983386703 (1989)? Will appreciate your help. Share this post Link to post Share on other sites
lynnmor 7,559 #4 Posted September 25, 2023 The spacers are shown on the bottom of the adjuster in this drawing. Share this post Link to post Share on other sites
peter lena 9,088 #5 Posted September 25, 2023 @gwood question , what are you trying to improve on ? height , back / forth ? angle ? done a number of seats , found , sitting along side that problem area , stool , gives you the view possible change ? spot / area , obviousely not as quick / easy for your issue . have also re drilled and extended mounting points . Pete Share this post Link to post Share on other sites
gwood 16 #6 Posted September 25, 2023 5 hours ago, lynnmor said: The spacers are shown on the bottom of the adjuster in this drawing. Thank you for responding lynnmor. I see that on the drawing you sent! I need to bring the back of the seat higher and it looks like Peter Lena has a way to do that. You have a wonderful day! Share this post Link to post Share on other sites
peter lena 9,088 #7 Posted September 25, 2023 @gwood scroll down on paint recovery , notice the bolt on coils ? , changed out the seat base , so I could do it , really helps , seat angle , experiment , if you want to , pete Share this post Link to post Share on other sites
gwood 16 #8 Posted September 25, 2023 2 hours ago, peter lena said: @gwood question , what are you trying to improve on ? height , back / forth ? angle ? done a number of seats , found , sitting along side that problem area , stool , gives you the view possible change ? spot / area , obviousely not as quick / easy for your issue . have also re drilled and extended mounting points . Pete Hi Pete and thanks for getting back to me! I didn't ask about how to raise the back of the seat in my question because I just believed all 4 spacers had to be installed. I tried to put a spacer at the rear of the seat between the spring and the swivel plate but seemed like that will put to much angle pressure on the front bolts? Just brought your additional comments on my 1Pad and will now go to that to follow your them. Thanks Pete! 1 Share this post Link to post Share on other sites
gwood 16 #9 Posted October 9, 2023 On 9/25/2023 at 8:13 AM, peter lena said: @gwood question , what are you trying to improve on ? height , back / forth ? angle ? done a number of seats , found , sitting along side that problem area , stool , gives you the view possible change ? spot / area , obviousely not as quick / easy for your issue . have also re drilled and extended mounting points . Pete Peter, I apologize for not sending you an response to my seat question! I appreciate the possible change of raising the 520-H rear seat height but decided to leave it unchanged because I want to keep it as original as possible. Have a couple other s I may want to do as you recommended, Thanks for your expertise! Gary 1 Share this post Link to post Share on other sites
