23 Reo 229 #1 Posted September 16, 2023 Please remind me of what size battery my 68 Charger 12 uses. Who sells these batteries at a fair price? 1 Share this post Link to post Share on other sites
ebinmaine 67,444 #2 Posted September 16, 2023 If it's the standard Garden Tractor battery it's a U1 or U1R. If it's the larger size it could have been a group 24NF but I use group 35 with a small wooden spacer to take up slack. Both of my C-160S have that. Many salvage yards sell used batteries. 1 1 Share this post Link to post Share on other sites
ri702bill 8,316 #3 Posted September 16, 2023 (edited) The most common battery size for a WH is either U1, or U1-R (posts reversed) Get one with at least 400 CCA - same physical size. Walmart or Tractor Supply. Either way - check the "Date Made", not the "Date Shipped" sticker - like bread, the fresher, the better. Prices have shot up, warranty coverage the other way. Got into a tinklefest over the difference of those stickers with a FORMER Tractor Supply worker.. Edited September 16, 2023 by ri702bill 1 1 Share this post Link to post Share on other sites
peter lena 8,617 #4 Posted September 16, 2023 @23 Reo LAST TIME AT WALLY300, cca 32$ , noted a 350 cca T bout $ 52. pete 1 1 Share this post Link to post Share on other sites
JCM 9,131 #5 Posted September 16, 2023 I use NAPA Batteries Dave and they last for years when taken care of. See Dave at the Ipswich,Ma NAPA store. If your not sure measure your battery tray etc . He will help you and tell him I said Hi. 1 2 Share this post Link to post Share on other sites
ebinmaine 67,444 #6 Posted September 16, 2023 2 hours ago, ri702bill said: Prices have shot up, warranty coverage the other way. That's why I stared getting salvage yard batteries. $25-$40 and they last several years. 1 1 Share this post Link to post Share on other sites
Achto 27,567 #7 Posted September 16, 2023 This is an average price for a 22NFD battery, if that is what you need. https://www.oreillyauto.com/detail/c/lawn-garden/super-start-lawn-garden-battery-group-size-22nf/sbe1/22nf/v/a/127768/automotive-suv-2014-jeep-cherokee 2 1 Share this post Link to post Share on other sites
peter lena 8,617 #8 Posted September 16, 2023 @23 Reo also have a battery tender set up , on each of my horses , plug in is attached to the choke cable , TYE wrapped in place for easy access, Pete 4 1 Share this post Link to post Share on other sites
JCM 9,131 #10 Posted September 16, 2023 Are you using this machine year round and not for winter duty. If a good weather tractor you can opt for less cold cranking amps and store the battery in a warm area for Winter. Will save some money doing it that way. I can't say enough about NAPA batteries. 3 Share this post Link to post Share on other sites
peter lena 8,617 #11 Posted September 16, 2023 @23 Reo improvement pictures , scroll down to the 5 th picture , notice the battery tender plug in ? also note the battery ground cable going to engine corner/ frame , for early RECTIFIER grounding improvement , now I just go directly to the rectifier mount bolts , don't get me started , pete 2 Share this post Link to post Share on other sites
23 Reo 229 #12 Posted September 16, 2023 I put all my summer (tractor and car) batteries in my basement for winter. They are cleaned and distilled water is added if needed. I then put them on an old bookshelf with the positive terminals out. They are then fully charged with the charger moving to the next battery in line. I repeat the charging process about once a month until spring. I've always been concerned that a tender could fry my battery if I keep it connected for a long period of time. 1 Share this post Link to post Share on other sites
ebinmaine 67,444 #13 Posted September 17, 2023 12 hours ago, 23 Reo said: I put all my summer (tractor and car) batteries in my basement for winter. They are cleaned and distilled water is added if needed. I then put them on an old bookshelf with the positive terminals out. They are then fully charged with the charger moving to the next battery in line. I repeat the charging process about once a month until spring. I've always been concerned that a tender could fry my battery if I keep it connected for a long period of time. We do a very similar setup here. Same lineup. Same procedure. Same concern about toasting a battery. My battery tenders are 1 amp manual. The charger I use is fully automatic. If/when I forget to switch them over it won't overcharge. 2 1 Share this post Link to post Share on other sites
lynnmor 7,305 #14 Posted September 17, 2023 14 hours ago, JCM said: Are you using this machine year round and not for winter duty. If a good weather tractor you can opt for less cold cranking amps and store the battery in a warm area for Winter. Will save some money doing it that way. I can't say enough about NAPA batteries. NAPA batteries are made by East Penn, any brand made by them are the same, only prices vary a lot. Batteries last longer if kept at low temperatures, one study is below. Lead Acid Batteries Effect of Temperature Effect of temperature on battery life Lead acid batteries are cost effective and reliable, making them suitable for many applications. One serious drawback compared to some other batteries (NiCad for example), is that lead acid batteries are affected by temperature. Lead acid batteries should only be used where they are installed in conditioned environments not subject to excessive temperatures. Typically the rating for lead acid batteries is based on an ambient temperature of 25oC. For every 8oC above ambient during use, the life of the battery will be reduced by 50%. Ideally batteries should be operated at 25oC or less. In addition to operation, storage of batteries waiting for use is also affected by temperature. If lead acid batteries are stored at elevated temperatures (particularly in a discharged condition), they will effectively become useless. If storing batteries, they should be in charged and stored at 25oC or less. Batteries will self discharge over time and need to be recharged periodically. 2 2 Share this post Link to post Share on other sites
ebinmaine 67,444 #15 Posted September 17, 2023 1 hour ago, lynnmor said: Typically the rating for lead acid batteries is based on an ambient temperature of 25oC. For every 8oC above ambient during use, the life of the battery will be reduced by 50%. Ideally batteries should be operated at 25oC or less. That chart looks about like what I've been told but translated to F⁰. It starts at 15⁰C. About 59⁰F. I've been under the impression for many years that a battery should be stored between 45⁰F and 70⁰F so that all jives well. 2 Share this post Link to post Share on other sites
