SylvanLakeWH 27,518 #1 Posted September 16, 2023 (edited) Went to get the E-141 SolarExpress ready for train duty and nothin, nada, zip... looked at the power disconnect and sure enough same issue as the A-60... Not sure though if Dans same fix? @Achto @wallfish @WHX?? https://www.amazon.com/Tocas-Surface-Mount-Circuit-Breakers-Waterproof/dp/B07D7S2VBY/ref=sr_1_5?keywords=70%2Bamp%2Bcircuit%2Bbreaker&qid=1692491449&sr=8-5&th=1 They have a breaker 120 amp but not 125... Part 19 - 125 amp fuse... Definitely the issue - I jumped it with clips and it fired right off... Help...advice...please... Edited September 16, 2023 by SylvanLakeWH 1 Share this post Link to post Share on other sites
squonk 42,527 #2 Posted September 16, 2023 You could probably rig something like this up. https://www.mcmaster.com/products/fuses/ 3 1 Share this post Link to post Share on other sites
ri702bill 8,969 #3 Posted September 16, 2023 Am I all wet, or did IT get wet??? Looks like a lot of discoloration (aka resistance) that could push it over the top..... 1 Share this post Link to post Share on other sites
wallfish 17,493 #4 Posted September 16, 2023 Age and oxidization may have cracked it? IDK Typically there would be a black spot if it burnt. 20 minutes ago, squonk said: You could probably rig something like this up. https://www.mcmaster.com/products/fuses/ Or it might fit right on there. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,518 #5 Posted September 16, 2023 15 minutes ago, ri702bill said: Am I all wet, or did IT get wet??? Looks like a lot of discoloration (aka resistance) that could push it over the top..... Most likely... sat in a field from what i understand... Share this post Link to post Share on other sites
SylvanLakeWH 27,518 #6 Posted September 16, 2023 40 minutes ago, wallfish said: Age and oxidization may have cracked it? IDK Typically there would be a black spot if it burnt. Or it might fit right on there. It cracked but no sign of sparks, discoloration etc... Pretty thin metal... @squonks fuse is 2" hole to hole. Mine is 1.5"+/-... Could rig it maybe... 1 Share this post Link to post Share on other sites
wallfish 17,493 #7 Posted September 16, 2023 56 minutes ago, SylvanLakeWH said: Could rig it maybe... Looks like there's enough room to just drill new holes in the isolation board. Do all 4 of them with new bolts? Use a new piece of Masonite and make a whole new board? 3 1 Share this post Link to post Share on other sites
Kenneth R Cluley 582 #8 Posted September 16, 2023 We used to have "RENEWABLE" fuses that were just a cartridge with ends that attached to an element similar to that part. Available in different amperage ratings. Check fleabay, etc.? 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,518 #9 Posted September 18, 2023 (edited) Got her done... nothing with the correct pole distance so dremmel tooled a slight mod and fits like a glove. Thanks all for your suggestions-greatly appreciated!!! Edited September 18, 2023 by SylvanLakeWH 3 2 Share this post Link to post Share on other sites
johnnymag3 2,559 #10 Posted October 12, 2023 Nice use of Dielectric Grease !!! Great job !! John 1 1 Share this post Link to post Share on other sites
