Bob Bauer
K 91 valve
Bob Bauer
So I’m replacing the valves on a k 91 and as careful as I was I messed up the intake by taking off 2 thousands of inch more than called for. So do you think I will be alright with that or should I replace? Thanks
ri702bill
If you cut the valve seat, just a tad, it will sink the valve a bit to get your .002 and a bit more back. Cut the seat, hand lap the valve to get a decent seating pattern, Remeasure the valve clearance and re-cut the stem.....BT,DT.... :thumbs2:
Edit - Grinding the valve angled surface does the same thing.....
Bill
Edited by ri702bill
  • Excellent 2
gwest_ca
It will not take much lapping to get that .002" back.
ri702bill
agreed - as long as it is by hand a a good cup or morning coffee.....
