ebinmaine 67,420 #26 Posted September 10, 2023 On 9/8/2023 at 8:54 PM, formariz said: Door design is relatively simple for your purpose and it probably won’t differ much from each other. As for hardware I probably have more than enough and will never use it. Hardware will vary as per door size and weight . I have a large variety of it in stock here. Caz I'll run this by Trina and see what we come up with. Thank you very much. As far as the floor or ceiling supports... I've spoken to the builder about the construction of these pole type buildings. The poles are in the ground 4+ feet and obviously quite strong... but... the walls are not. The vertical outer boards are supported by the horizontal purlins set outside the poles. Neither of those are meant to carry bunches of extra weight. That's the reasoning behind needing a roller on the floor, or hanging from the roof trusses. In my case I'd likely do the floor roller because of ease and keeping the weight off the structure. Most of the weight would be resting on the concrete. 3 Share this post Link to post Share on other sites
AMC RULES 37,130 #27 Posted September 10, 2023 For the upcoming holidays... here's a nifty gift idea for Trina. Just sayin... 1 1 Share this post Link to post Share on other sites
