ky stone horse 3 #1 Posted September 6, 2023 I recently acquired ac-120 that has the Tecumseh 16 hp on it (its toast) what engine is the easiest and most economical repower engine i should try??? Sorry guys im a greenhorn but love these tractors any help be greatly appreciated 3 Share this post Link to post Share on other sites
Sparky-(Admin) 22,056 #2 Posted September 6, 2023 For general dependability I would recommend a Kohler K-Series. Say a 10hp-16hp single cylinder. It will also fit without chopping the hood. If you could find one still in a “junk C-series tractor” (I’m gonna get flack for that junk comment ) that would get you the correct ignition, charging components and choke/throttle cables that you would also need. The PTO parts might also be different between the Tecumseh and Kohler, another reason to find a complete tractor as a parts donor. Since that Teccy 16 is not original I wonder if yours was originally a Kohler powered machine? Post up the model number on the tractors data plate and we can give you better info on how it started out in life. 10 1 Share this post Link to post Share on other sites
Pullstart 64,522 #4 Posted September 6, 2023 there are some pretty fart smellers around these parts, and if you have an issue it’s likely one of us has come across the answer a time or two. 2 5 Share this post Link to post Share on other sites
ebinmaine 70,710 #5 Posted September 6, 2023 As indicated above we really need to get a little more information and especially some pictures. Model number do you have? Was it originally a c-120 with a Tecumseh? What engine is in there now? Why do we think think it's gone bad? Has proper testing been done? Or is it something simple like a hole in the side of the block or it's frozen? 2 Share this post Link to post Share on other sites
daveoman1966 3,807 #6 Posted September 6, 2023 (edited) I have a 12hp Kohler (K301s) from a C-120 Auto that runs ok. $250... come and get it. $300 for remainders of entire 'parts' C-120. Located at zip 16433.. about 40m south of Lake Erie, PA. I have video of it running, but can't seem to get that video to upload to RS. Edited September 6, 2023 by daveoman1966 2 Share this post Link to post Share on other sites
953 nut 57,878 #7 Posted September 6, 2023 3 hours ago, Sparky said: a “junk C-series tractor” I have seen some cosmetically challenged "C" Series Wheel Horses and some that had been abused, but JUNK C Series That is non existent! 10 hours ago, ky stone horse said: im a greenhorn but love these tractors Since the engine that came with your is not the one it left the factory with there will probably be wiring and control cables that have been altered too. We are here to help and give you the guidance needed to make the old "C" new again. A parts donor tractor with a good engine would be ideal because all the associated cables and wiring would be included. Happy hunting. Let us know what you find before you make a purchase so we can give some input on what the pros and cons may be. 3 1 Share this post Link to post Share on other sites
WHX?? 50,709 #8 Posted September 6, 2023 Sounds like @daveoman1966 may have you covered with a donor tractor. 1 hour ago, 953 nut said: JUNK C Series That is non existent! There's your flack Sparky... 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,510 #9 Posted September 6, 2023 @Sparky 1 Share this post Link to post Share on other sites
Sparky-(Admin) 22,056 #10 Posted September 6, 2023 Lol! I knew I should have worded that “junk” comment a little bit differently 1 2 Share this post Link to post Share on other sites
Ed Kennell 40,466 #11 Posted September 6, 2023 to the These s will have thier fun, but will get you help. BTY, most of us are confused. 2 Share this post Link to post Share on other sites
oliver2-44 10,367 #12 Posted September 7, 2023 Love my C Series workers. Of course I love em all! 1 Share this post Link to post Share on other sites
