leeave96 488 #1 Posted September 4, 2023 Anyone change a bad Onan to a single cylinder Kohler K or Magnum engine? What kind of a job was it - gravey or just scrap the tractor and find anither one - LOL? 2 Share this post Link to post Share on other sites
ebinmaine 70,717 #2 Posted September 4, 2023 A. NEVER scrap a tractor. Please part it out instead. The 520H front axle and steering is valuable. B. I believe a Magnum engine will have a similar wiring setup. I know it's been done by more than a few folks over the years. 3 Share this post Link to post Share on other sites
Handy Don 13,340 #3 Posted September 4, 2023 Depending on what you are asking the tractor to do (i.e. how much power you really need) a “bad” Onan to K swap should be straightforward--both are battery coil engines. Some physical stuff might need small tweaks, like engine mounting, wiring hookups, throttle & choke cables, and fuel line. 1 Share this post Link to post Share on other sites
953 nut 57,885 #4 Posted September 4, 2023 Engines are bolted to the frame or a steel plate bolted to the frame. If you own a drill the sap should be easy to accomplish. If both engines have battery powered ignition the electrical hook up should be easy enough. If the replacement engine has a magneto ignition then a kill relay will need to be added, the thread below will give you the needed information. The nine pin connector is an Onan thing and all you need to remember is the wires to the nine pin are color coded and can be run to the appropriate places on the replacement engine. Light blue to Solenoid, Orange/yellow to ignition coil, Red to voltage regulator B+ terminal, and Black wirer to ground on the engine. The gray wire will not be used because you don't have a tachometer hook-up and the dark blue wire won't be used because you won't have an oil pressure sender. 1 Share this post Link to post Share on other sites
leeave96 488 #5 Posted September 5, 2023 Thanks for the replies everyone - much appreciated! Share this post Link to post Share on other sites
