"Manic-Mechanic" 1,228 #1 Posted August 29, 2023 Purchased a ISaveTractor's Carb for K series 241a, ended up installing on M12 (as the linkage is included for either) 2 Share this post Link to post Share on other sites
peter lena 9,087 #2 Posted August 29, 2023 @Manicmacanic always looking for an improvement , BTW have an added ground on that rectifier ? from the battery ground bolt ? also have carb from I SAVE TRACTORS , NEVER TOUCHED ITS ADJUSTMENT , been bombproof , pete Share this post Link to post Share on other sites
ebinmaine 70,718 #3 Posted August 29, 2023 58 minutes ago, "Manic-Mechanic" said: ISaveTractor's Carb I've only had one here. Looked good. Ran fine. I removed it to do some other work and discovered that the top pivot was excessively worn after a short time. Keep an eye on that. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #4 Posted August 29, 2023 4 hours ago, ebinmaine said: I've only had one here. Looked good. Ran fine. I removed it to do some other work and discovered that the top pivot was excessively worn after a short time. Keep an eye on that. I'll more than likely rebuild my factory carb, but yes, will do thank's 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #5 Posted August 29, 2023 4 hours ago, peter lena said: @Manicmacanic always looking for an improvement , BTW have an added ground on that rectifier ? from the battery ground bolt ? also have carb from I SAVE TRACTORS , NEVER TOUCHED ITS ADJUSTMENT , been bombproof , pete Funny you just mentioned the ground my rectifier does drop off every now and then. I usually have to wiggle the harness around behind the ignition. I replaced all that circuit, was a nightmare from prior owner! Have to run that ground next thing! Thanks' 1 Share this post Link to post Share on other sites
peter lena 9,087 #6 Posted August 29, 2023 @Manicmacanic yes that insured grounding , from the battery ground bolt , really wakes up that amp gauge , came to that with typical erratic amperage readings . you can try it first with an alligator clip connection , made up a couple of heavier eye bolt to wire end connection , did it on test tractor , then ran it on my other 2 horses . thats how I do all of my experiments , tractors are all set up the same , so if improve an area , its east to duplicate to the others. did a similar experiment on mower deck bearings , basically lubrication failure . opened up every related bearing , re pack with a 550 degree polyurea grease , no whyining noise , smooth / quiet . did the same to the other 2 horses. pete Share this post Link to post Share on other sites
