jgun45879 191 #1 Posted August 27, 2023 I have a 2003 315-8 tractor with the Command Pro 15hp engine....The model is CH15S....The Spec number is 44533...The number on carburetor is 1205375 C128041.....Im having trouble finding the correct carburetor rebuild kit....just about every one i find doesnt have the correct size bowl gasket and needle valve....Can someone point me in the right direction...Thank You. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #2 Posted August 27, 2023 Found the carb number in the carb manual but no parts listed. Went to the ipl for the tractor and the Kohler parts are broken down. The carb kit is 1275727-s Be careful with kits - the complete carb is also called a kit. https://www.partstree.com/parts/kohler-12-757-27 - very proud of their parts. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #3 Posted August 27, 2023 Here is the carb manual, There is a left and right page so keep that in mind. You can only see one page at a time. 2 Share this post Link to post Share on other sites
jgun45879 191 #4 Posted August 28, 2023 That helps....Thank You. Share this post Link to post Share on other sites
RED-Z06 2,479 #5 Posted August 29, 2023 Ive run into this before on other equipment. I think, somewhat briefly, Kohler used Nikki carbs on the Command singles and then went to Walbro again, most part lists only offer the walbro replacement and no "rebuild kit". So its possible you have the oddball Nikki...and Kohler just kinda..pretends it doesn't exist Share this post Link to post Share on other sites
