Micheal Cavallaro 0 #1 Posted August 21, 2023 i have recently replaced the motor on my 1057 from a Koler k241 to some sort of 8 to 10 horsepower craftsman and i did not take a picture of the wire on the bottom of the voltage regulator i Rember a is armature and f is field. but the wire on the bottom has no memory or idea where it goes so i watched every video i could and they coved most other parts except the bottom wire. i used this voltage regulator from i save tractors Voltage Regulator for Kohler K series and Briggs and Stratton with Starter Generator (isavetractors.com) if can help me thank you if you can't i will put a alternative charging system. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #2 Posted August 21, 2023 Click on the picture in the link to see a wiring diagram 2 Share this post Link to post Share on other sites
ri702bill 8,738 #3 Posted August 21, 2023 This ancient Delco Remy literature explains a lot. DO check your voltage at the battery at half to full throttle when done. Delco Remy Regulator Manual 1R-116.pdf Share this post Link to post Share on other sites
953 nut 56,742 #4 Posted August 21, 2023 This drawing should be helpful. Share this post Link to post Share on other sites
pfrederi 18,180 #5 Posted August 21, 2023 If there is a terminal on the bottom it is the "A" and wire goes to A on the generator. Upper Terminals from left to right will be "L" load (for lighter/lights) "BAT" battery positive and "F" Field goes to F on the generator. 3 Share this post Link to post Share on other sites
