divemaster5734
16-38 HXL stalls out in gear
divemaster5734
Hello,
I have a 16-38 HXL that I've removed the deck and use with a dump trailer around the yard.
It's been very reliable with basic maintenance.
Until now.
The engine fires right up, has a solid low idle, but as soon as I take off the break it stalls out.
I had just put some gas in it and just in case it was bad I emptied the tank and put some 97 octane that's a custom mix I use for racing motorcycles.
It's not high enough to burn holes but bikes and chainsaws love it.
There was a pronounced improvement, and it continued to run when I let off the brake, but then stalled again with forward throttle.
Thinking of it, there is a slight chance I may have been a little impatient waiting for the new gas to go through.
I had cut in a fuel switch to allow me to change out the extra fuel filter I put inline, so I drained the tank from there, about 4" from the carb intake.
Anyhow, I'm hoping for some advice in case it continues to die out next week.
Thanks
gwest_ca
What is the model number and serial number of the tractor?
Is there a chance the ignition is being shut off by one of the safety switches?
In the wiring I looked at don't see a brake switch.
lynnmor
The higher the octane, the lower the chance for burning a piston.  For your tractor, any fresh regular gasoline with no more than 10% ethanol will be just fine.  My guess is that you have debris in the carburetor.
peter lena
@divemaster5734 agree with @gwest_ca  on possible safety switch connection , actually that consistant related failure is what you want , process of elimination to run / stop , usually make a failure spot , a solid / strong finish spot . would also check  all related wiring  / connections , cracked / shorted  etc , might use an alligator  clip  test wire as a jumper connection . easy to drop that carb bowl , refresh the gas filter . basic stuff.  read your octaine set up , its the ethenol that destroyes fuel lines , been adding , STA -BIL fuel to my fuel for years , its a storage additive , no crud in tank / carb / fuel filters , just some ideas . pete
ineedanother
My suspicion is that the bowl on your carburetor has a fair amount of water in it.
