mike avad 44 #1 Posted August 17, 2023 are there oil seal for the tine ? I just got this a few day's ago and have some gear oil come from around the tine shaft and around where the big pully there a not tag on this for info so am able to find the right seal's and am not sure if this is the right part's I need #103118 tiller #100441 oil seal. this what I found on wheel horse part's and more.THANK YOU 1 Share this post Link to post Share on other sites
Pullstart 64,523 #2 Posted August 17, 2023 Lowell has all kinds of hard to find stuff. If he says it’ll fit, it’ll fit 1 Share this post Link to post Share on other sites
JoeM 7,924 #3 Posted August 17, 2023 If it is just a slight leak, might just think about topping off before you use it. those seals on the tines are hard to keep from leaking once they start. another options is John Deere corn head grease. there is not much more in those tiller cases than a chain drive and some bearings. 3 Share this post Link to post Share on other sites
pfrederi 18,328 #4 Posted August 17, 2023 (edited) If you want the tines shaft seal #7 it is WH 100318 and you need 4 2 per side SKF 12330 Input shaft is 100441 only 1 needed SKF 7410 Edited August 17, 2023 by pfrederi 3 Share this post Link to post Share on other sites
mike avad 44 #5 Posted August 24, 2023 I'D hate to pull the gear box apart with have any part number for this tiller so i'll try the corn head grease it just came out of the one side when I lay it on it's side. thanks guy for all your reply am a new B on this wheel horse thing list and learn here. Share this post Link to post Share on other sites
