GTSRider@yahoo.com 0 #1 Posted August 13, 2023 Looking at an almost mint C-105 ....but my property is hilly , and I need a posi rear end . Does the C-105 have a posi rear end ? Share this post Link to post Share on other sites
wallfish 17,193 #2 Posted August 13, 2023 No . Only older WH tractors had a limited slip trans But traction issues can be solved with weight placed in proper positions and or better traction tires. (wheel weights, chains, AG tires etc. ) If it's that "hilly" I would be more concerned about having an oil pressure engine. Like with an oil pump instead of splash lubed. Splash lube engines could experience lubrication problems if on constant angles which are to steep to properly splash lube. 5 1 Share this post Link to post Share on other sites
SylvanLakeWH 26,591 #3 Posted August 13, 2023 Great tractor!!! Share this post Link to post Share on other sites
