ridetjz 0 #1 Posted August 12, 2023 Hello I recently acquired a 257H with a hydro transmission. While I am turning it over it wants to start rolling/buck forward is this a clutch adjustment issue I see there is a threaded rod on the underside. Would anyone know the procedure to adjust this. Any help would be appreciated. Thank you Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #2 Posted August 12, 2023 Welcome to Red Square. Sounds like you could use a service manual Here is what comes up with a 257-H search. Searching for the model number would reduce the hits. Post the model and serial number if you have them. https://www.wheelhorseforum.com/search/?q=257-h&quick=1&type=downloads_file 1 Share this post Link to post Share on other sites
