moe1965 766 #1 Posted August 10, 2023 I'm looking for a oil seal for for a 5053 trans. I'm looking for the input shaft seal. The pdf file has a # reference as 1303 this is no longer a good number from my research. Its a .750 shaft. Thanks for any help Share this post Link to post Share on other sites
Achto 30,175 #2 Posted August 10, 2023 (edited) 9 minutes ago, moe1965 said: The pdf file has a # reference as 1303 this is no longer a good number from my research. SKF 7410 Check out the cross reference sheets. Edited August 10, 2023 by Achto 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #3 Posted August 10, 2023 The PDF shows the Wheel Horse number (so you can match to a schematic) then gives a vendor number so you can buy the seal, or cross reference to a different manufacturer. The chart shows 1303 then shows the new number 100441 (also a WH number). Then shows the SKF number #7410. The 7410 is the number to use to buy or cross to ...like National seals. 2 Share this post Link to post Share on other sites
