NinjaHorse 12 #1 Posted August 8, 2023 Hey there! How's it going!! Has anyone put clock-wise driven PTO motor on a wheel Horse? 2 Share this post Link to post Share on other sites
Ed Kennell 38,181 #2 Posted August 8, 2023 to the I have never seen one, but i'm sure it could be done. It would take a lot of belt twisting to get the transmission, deck, snow blower, and tiller to turn in the correct direction. 2 Share this post Link to post Share on other sites
ebinmaine 67,535 #3 Posted August 8, 2023 I'm curious to know what brings up the question.... 4 Share this post Link to post Share on other sites
953 nut 55,261 #4 Posted August 8, 2023 As far as I know all small engines have a clockwise rotation on the flywheel end of the crankshaft and counter- clockwise on the output (PTO) end. What engine are you planning to use? 1 Share this post Link to post Share on other sites
pacer 3,173 #5 Posted August 9, 2023 I guess there are some engine/s that run CW on pto side, but I've never seen one.......... Sounds like would be a real pill to make one work. 1 Share this post Link to post Share on other sites
kpinnc 12,065 #6 Posted August 9, 2023 (edited) 1 hour ago, 953 nut said: As far as I know all small engines have a clockwise rotation on the flywheel end of the crankshaft and counter- clockwise on the output (PTO) end. What engine are you planning to use? I've seen golf cart gas engines that crank both directions, tied to a torque converter. That's what allowed for reverse. I wanna say they were made by Robin? I know transverse mounted engines like how Cub, Case, Ford, Simplicity and others alternated which side of the engine faced forward. That made for left-discharge mower decks on the Case tractors. But all of those engines turned the same direction. Edited August 9, 2023 by kpinnc 3 Share this post Link to post Share on other sites
ineedanother 1,369 #7 Posted August 9, 2023 6 minutes ago, kpinnc said: I've seen golf cart gas engines that crank both directions, tied to a torque converter. That's what allowed for reverse. I wanna say they were made by Robin? I can see that (kinda) in a 2 stroke but not in 4...? Interesting 3 Share this post Link to post Share on other sites
kpinnc 12,065 #8 Posted August 9, 2023 3 minutes ago, ineedanother said: I can see that (kinda) in a 2 stroke but not in 4...? Interesting You're correct. I should've clarified that it was two stroke. 2 Share this post Link to post Share on other sites
Rick3478 428 #9 Posted August 9, 2023 You didn't say what model WH, some may be easier than others. Mower deck with the front mule drive is pretty easy to reverse, but transmission and some of the other attachments not so much. If it's a two stroke, can you contrive to start it the other direction? Or rotate the engine and mount PTO to the flywheel side? Or add a jack shaft? 1 Share this post Link to post Share on other sites
Pullstart 62,902 #10 Posted August 9, 2023 I’d believe other than being for oddity’s sake, it would be worth finding a more suitable engine if needed… 4 1 Share this post Link to post Share on other sites
NinjaHorse 12 #11 Posted August 9, 2023 Thank you for the input guys!! What bring up the question is kinda an unconventional set up. I had acquired two things one was a 312-8 Wheel horse and the other was a EX500 motor. I both had their major issues, but both of them together made a useable machine again!! I got it all put together and running then realized that the Kohler motor that was on the Wheel horse ran PTO CCW. I was just curious if there was any system or something out there that I can put on to change direction back to CCW, or if there was something I could do to the transmission to reverse the final drive and keep the gears. For now I twisted the drive belt, not ideal but works. I would like to get something figured out so I can at least put the mower deck on and running. 2 Share this post Link to post Share on other sites
kpinnc 12,065 #12 Posted August 9, 2023 (edited) 49 minutes ago, NinjaHorse said: I had acquired two things one was a 312-8 Wheel horse and the other was a EX500 motor. As in Kawasaki EX500? Good Lawd!!!!! Edited August 9, 2023 by kpinnc 3 Share this post Link to post Share on other sites
NinjaHorse 12 #13 Posted August 9, 2023 20 minutes ago, kpinnc said: As in Kawasaki EX500? Good Lawd!!!!! Yes! just so happens to fit perfectly under the hood and on the frame. 2 Share this post Link to post Share on other sites
wallfish 17,000 #14 Posted August 9, 2023 (edited) Running the mower deck is the biggest problem. You can turn the engine around and use a jackshaft with 2 bearings set up in between the engine and trans with 2 pulleys on it to get the correct drive rotation. Maybe an extra pulley on the trans input side and use an older 60s style pedal to engage the belt for a deck. ??? Edited August 9, 2023 by wallfish 7 Share this post Link to post Share on other sites
Wild Bill 633 846 #15 Posted August 9, 2023 A motorcycle transmission output shaft rotates CCW and is on the LH side. The brake shaft on an 8-speed transmission is also on the LH side and rotates CCW. You could run a chain drive from the cycle transmission to the brake shaft, thus not using the gears in the WH transmission. @Pullstarttried this on his Snowmotractor and got the idea from another WH member. 2 1 Share this post Link to post Share on other sites
NinjaHorse 12 #16 Posted August 9, 2023 44 minutes ago, wallfish said: Running the mower deck is the biggest problem. You can turn the engine around and use a jackshaft with 2 bearings set up in between the engine and trans with 2 pulleys on it to get the correct drive rotation. Maybe an extra pulley on the trans input side and use an older 60s style pedal to engage the belt for a deck. ??? Yeah I think that's where I lost it when building this set up, that is exactly what I did, and the realized that it is spinning the wrong direction. I'll try and attach a photo of what I made. 3 Share this post Link to post Share on other sites
NinjaHorse 12 #17 Posted August 9, 2023 (edited) 23 hours ago, Wild Bill 633 said: A motorcycle transmission output shaft rotates CCW and is on the LH side. The brake shaft on an 8-speed transmission is also on the LH side and rotates CCW. You could run a chain drive from the cycle transmission to the brake shaft, thus not using the gears in the WH transmission. @Pullstarttried this on his Snowmotractor and got the idea from another WH member. Nice!! I had an idea like that, I didn't think that was a thing but that's why I decided to jump on this forum and just see what people have come up with! Thanks!! Edited August 10, 2023 by NinjaHorse 1 Share this post Link to post Share on other sites
NinjaHorse 12 #18 Posted August 9, 2023 49 minutes ago, NinjaHorse said: Nice!! I had an idea like that, I didn't think that was a thing but that's why I decided to jump on this form and just she what people have come up with! Thanks!! Wow!!! Yeah I just went and watched his youtube videos on the Snowmotractor!! I think that is the route I am going to go! Thank you so much for letting know about him @Pullstart!! 1 1 Share this post Link to post Share on other sites
Pullstart 62,902 #19 Posted August 10, 2023 It’s loaded in the old Chevy for a car show tomorrow! Still kickin around different ideas to make it get to 55-60 mph! 1 3 Share this post Link to post Share on other sites
kpinnc 12,065 #20 Posted August 10, 2023 6 hours ago, wallfish said: Running the mower deck is the biggest problem. Would you really use a mower deck with a 50hp high RPM engine? Nevermind. Now that I read my question, I feel like I know the answer from this crowd... 7 Share this post Link to post Share on other sites
wallfish 17,000 #21 Posted August 10, 2023 6 hours ago, kpinnc said: Would you really use a mower deck with a 50hp high RPM engine? Nevermind. Now that I read my question, I feel like I know the answer from this crowd... I wouldn't but here was what that reply was for 14 hours ago, NinjaHorse said: I would like to get something figured out so I can at least put the mower deck on and running. 1 Share this post Link to post Share on other sites
kpinnc 12,065 #22 Posted August 10, 2023 (edited) 5 hours ago, wallfish said: I wouldn't but here was what that reply was for Oh no I just had the mental image of a 40mph mower! Edited August 10, 2023 by kpinnc 4 Share this post Link to post Share on other sites
Pullstart 62,902 #23 Posted August 10, 2023 About 10 years I knew a lady who’s brother had an old Camaro on a K5 blazer frame, with a 6’ woods belly mower on it. We dubbed it the Camower for him. I’m not sure if he ever knew that, but we were just talking about it’s versatility today! 2 Share this post Link to post Share on other sites
wallfish 17,000 #24 Posted August 10, 2023 5 hours ago, kpinnc said: Oh no I just had the mental image of a 40mph mower! I remember watching that tractor video. LOL It's quite impressive as that guy was MOVING ! Share this post Link to post Share on other sites
