scrams8g
1991 520H relays
scrams8g
I ran into this issue when ordering relays from Toro, you end up with relays made in China that have a vendor part number that doesn't match the original. There is a person on Ebay selling the original Cibie made in U.S.A relays. A little pricey but I think the quality is worth it.
Edited by scrams8g
Listed in wrong section.
lynnmor
They are a common relay available at any auto parts store.
scrams8g
My point was that you won't get the correct relay from Toro and you can get the exact same brand and part number on Ebay.
peter lena
@scrams8g  there is a commonality of electrical failures in those units , more often than not , stiff / chafing wiring , cracked / split connectors , poor grounding . this not a quick easy / one and done fix , BTW  that CIBIE  name is  french / lighting  / lights . still have a few from back in the day , like aircraft landing lights , turn them on ,and you can see for miles!  interstate driving at night , you pick up every reflective sign / for miles , MARSHALL  is another french driving light .  test light /  alligator  clip test wires .  good luck , pete
