TJ5208 1,824 #1 Posted August 1, 2023 Real quick question can you take a ignition out of a truck or a vehicle and put it on a Wheel Horse 1 Share this post Link to post Share on other sites
wallfish 17,486 #2 Posted August 1, 2023 Typically cars/trucks use a non resister type coil. ( but could also use an external resister) Kohler coils have a built in resister. You can buy an external resister for the truck coil A coil without a resister there will prematurely burn out the points but it will definitely fire it up Hope this helps. That's about the extent of my knowledge when it comes to those coils Share this post Link to post Share on other sites
TJ5208 1,824 #3 Posted August 1, 2023 1 minute ago, wallfish said: Typically cars/trucks use a non resister type coil. ( but could also use an external resister) Kohler coils have a built in resister. You can buy an external resister for the truck coil A coil without a resister there will prematurely burn out the points but it will definitely fire it up Hope this helps. That's about the extent of my knowledge when it comes to those coils I'm wanting to put one on my 520-8 Share this post Link to post Share on other sites
wallfish 17,486 #4 Posted August 1, 2023 That's an Onan engine. You can find Harley coils cheaper than Onan sells them. What exactly does it need ? 3 Share this post Link to post Share on other sites
TJ5208 1,824 #5 Posted August 1, 2023 1 minute ago, wallfish said: That's an Onan engine. You can find Harley coils cheaper than Onan sells them. What exactly does it need ? I'm wanting to put a key ignition on it it so its not a universal key. I'm trying to get it to where I can take a key that goes in a truck and use it on my tractor. 1 Share this post Link to post Share on other sites
wallfish 17,486 #6 Posted August 1, 2023 Do you have the ignition switch already? You can try to figure out how the wires connect to each other in the different key positions. You'll need + battery in and that needs to send power to the coil in the start position and turn it off in the off. It needs to keep power in the start position Then you will need to find a starter wire that only has + battery power in the start position and it needs to stop in the run position 1 Share this post Link to post Share on other sites
wallfish 17,486 #7 Posted August 1, 2023 Maybe a different type of key switch like this? I didn't check out this switch particulars to confirm it would work with a battery ignition like your engine but I don't think anyone in your neighborhood would have a key that fits. https://www.ebay.com/itm/313651602488?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A18QHST0QKSJu9_y6_XTyqhA40&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=313651602488&targetid=4580153136941813&device=c&mktype=&googleloc=&poi=&campaignid=437225722&mkgroupid=1224856224320848&rlsatarget=pla-4580153136941813&abcId=9300906&merchantid=51291&msclkid=5bb7d60d753f1bacd11fb2c4f3a8c06b 1 2 Share this post Link to post Share on other sites
Achto 28,774 #8 Posted August 2, 2023 (edited) On 8/1/2023 at 5:15 PM, TJ5208 said: I'm trying to get it to where I can take a key that goes in a truck and use it on my tractor. A switch like what @wallfish showed would be the way to go. The key switch in most cars & trucks do not have any electrical terminals on them. They are only used to move linkage that is connected to a switch box which is mounted lower down on the steering column. Example : Edited August 3, 2023 by Achto 1 3 Share this post Link to post Share on other sites
WHX?? 50,712 #9 Posted August 2, 2023 What kind of truck ig switch are we talking about? Not to discourage out the box thinking but would hate to see you let some smoke out. 2 Share this post Link to post Share on other sites
TJ5208 1,824 #10 Posted August 2, 2023 49 minutes ago, WHX?? said: What kind of truck ig switch are we talking about? Not to discourage out the box thinking but would hate to see you let some smoke out. Dodge Share this post Link to post Share on other sites
WHX?? 50,712 #11 Posted August 2, 2023 16 minutes ago, TJ5208 said: Dodge Alrighty then what year? Share this post Link to post Share on other sites
TJ5208 1,824 #12 Posted August 2, 2023 44 minutes ago, WHX?? said: Alrighty then what year? Not really worried about year want dodge key and ignition though Share this post Link to post Share on other sites
Achto 28,774 #13 Posted August 2, 2023 8 hours ago, TJ5208 said: Not really worried about year want dodge key and ignition though You would have to find one from an early model dash mount ignition. All steering column mounted switches will work like the Ford switch that I posted above. Share this post Link to post Share on other sites
TJ5208 1,824 #14 Posted August 2, 2023 Just now, Achto said: You would have to find one from an early model dash mount ignition. All steering column mounted switches will work like the Ford switch that I posted above. Ok so try to get one of those ford ones. Share this post Link to post Share on other sites
Achto 28,774 #15 Posted August 2, 2023 2 minutes ago, TJ5208 said: Ok so try to get one of those ford ones. No, what I'm saying is GM, Ford, Mopar switches that are mounted on the steering column of a car or truck will not work. They do not have any electrical terminals on them, they only move linkage that is connected to a large switch box which is mounted lower on the steering column. 1 1 Share this post Link to post Share on other sites
TJ5208 1,824 #16 Posted August 2, 2023 2 minutes ago, Achto said: No, what I'm saying is GM, Ford, Mopar switches that are mounted on the steering column of a car or truck will not work. They do not have any electrical terminals on them, they only move linkage that is connected to a large switch box which is mounted lower on the steering column. So what I'm trying to do will not work. 1 Share this post Link to post Share on other sites
Pullstart 64,522 #17 Posted August 2, 2023 Maybe just have someone 3D print you an overlay for an Indak key and call it a day? Of the hundreds of show tractors that have the same key, I’ve never heard of someone having a tractor stolen because of the universal key. 1 3 Share this post Link to post Share on other sites
Handy Don 13,340 #18 Posted August 2, 2023 A simple trick to discourage opportunistic “users” is to add a toggle switch behind the hoodstand that cuts off the power to the ignition switch. Or even put it in the dash with an odd label like “auxiliary”. 1 1 Share this post Link to post Share on other sites
953 nut 57,881 #19 Posted August 2, 2023 1 hour ago, Pullstart said: Of the hundreds of show tractors that have the same key, I’ve never heard of someone having a tractor stolen because of the universal key. At most shows you will see the keys left in the ignition switch! The likelihood of being able to buy two ignition switches keyed alike for any make vehicle is slim to none. A good locksmith could probably modify a key to work in both but that would drive the price up. You can find Security System switches with removable keys on or at shops that sell car audio systems. 1 1 Share this post Link to post Share on other sites
Pullstart 64,522 #20 Posted August 2, 2023 We had a kid’s quad with a remote shut off switch too. Keep the ‘mote in your pocket and shut ‘er down. 2 Share this post Link to post Share on other sites
Tractorhead 9,093 #21 Posted August 5, 2023 Or use simply a Pullstert Engine. The most be too lazy to use a simple Pullstart. 😎 that‘s the cheapest Way... imho Share this post Link to post Share on other sites
