Brockport Bill 1,786 #1 Posted August 1, 2023 i have 42" rear discharge mower decks ( # 15-42rc01 ) and plan to replace spindle bearings #109966 ---- also have 05-42mr01 --- bearing # 106085 ---------- can someone tell me the equivilant NAPA bearing numbers?? - thanks Share this post Link to post Share on other sites
peter lena 8,984 #2 Posted August 1, 2023 @Brockport Bill just checked , both of those / either bearing has the wide rubber side shields , perfect opportunity to do a carefull seal removal , clean out and repack with a hi temp grease , like a 550 + deg polyurea grease , it will not fail like the grease that was installed in there . only a suggestion , also do the same grease upgrade in the muel drive bearings , and inner needle bearing in the pto drive cone , imagine no bearing whine , solid smooth operation . only a suggestion , pete 3 Share this post Link to post Share on other sites
squonk 41,967 #3 Posted August 1, 2023 (edited) 109966 is 6203RSJ 106085 I cannot cross. Need dimensions. Possibly a 6203-12-2RS 3/4" ID X 40MM OD X 12MM Wide Edited August 1, 2023 by squonk 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #4 Posted August 2, 2023 Posted this in the past and do not recall how I figured it out The earlier decks used spindles with an odd 6203 bearing with a 3/4" ID x 40mm OD x 12mm deep. Bearing numbers 106084 and 106085. The number of seals being the difference. 2 Share this post Link to post Share on other sites
peter lena 8,984 #5 Posted August 2, 2023 @Brockport Bill my reference to those bearings , whas what you found, the opportunity to easily remove a wide rubber side shield , on ANY bearing , clean out / carb cleaner flush , repack to same ammount , with a hi temp , polyurea grease , will make a chronic problem go away . I use a very small putty knife or a small fine flat pocket screwdriver . every related pto driven pulley bearing , spins with ease , ever wonder why so many are replacing pto belt clutches ? have not replaced any of mine , a belt driven attatchment should be able to turn over easily , by hand ,between pto / muel drive area . all of mine do , no screaming clutch / bearing whine , quiet smooth solid . this is not , in the book , but if you are right at a chronic problem spot , why not make it go away ? pay attention to operational function / ease/ effort / change / improve , if you want to . repedative failure is showing you the way , take advantage of it , pete Share this post Link to post Share on other sites
Brockport Bill 1,786 #6 Posted August 2, 2023 2 hours ago, peter lena said: @Brockport Bill my reference to those bearings , whas what you found, the opportunity to easily remove a wide rubber side shield , on ANY bearing , clean out / carb cleaner flush , repack to same ammount , with a hi temp , polyurea grease , will make a chronic problem go away . I use a very small putty knife or a small fine flat pocket screwdriver . every related pto driven pulley bearing , spins with ease , ever wonder why so many are replacing pto belt clutches ? have not replaced any of mine , a belt driven attatchment should be able to turn over easily , by hand ,between pto / muel drive area . all of mine do , no screaming clutch / bearing whine , quiet smooth solid . this is not , in the book , but if you are right at a chronic problem spot , why not make it go away ? pay attention to operational function / ease/ effort / change / improve , if you want to . repedative failure is showing you the way , take advantage of it , pete i use those "dentist" type tools -- very effective -- thanks for your tips!!!!!!!!!!!!!!!!!!! 1 Share this post Link to post Share on other sites
peter lena 8,984 #7 Posted August 2, 2023 @Brockport Bill thank you bill,! just a chronic problem that I TOOK APART IN DETAILING IMPROVEMENTS , those seal covers are the type that I look for in every bearing if possble , typical lubricant , will not stand up to heat or angular stress . ANY NOISY BEARING IS TELLING YOU THAT , having been using that lucas green grease now for years , consistantly quiet / smooth . like to take things apart and find the cause of the issue , impove on that, and detail it in on improved function . that pto lever improvement makes that work wiith toral ease . good talking , thanks , pete 1 Share this post Link to post Share on other sites
