Rick 55 BB 24 #1 Posted July 31, 2023 I'm trying to replace the O-rings on my hyrdro motion lever , The problem is the 3 mounting bolts have an odd head on them , maybe a 12 point ? anyhow I can't find a socket to fit the and don't want to mess them up and not be able to get them out . Any help would be appreciated , thanks Rick Share this post Link to post Share on other sites
Gasaholic 254 #2 Posted July 31, 2023 Been at least 25 years since I worked on them but yes, 12 point socket - I believe it was a 12-point socket that we at the time had to run the O.D. down a tiny bit on a grinder to get it to fit in some of the recesses.. I think it was before Inverted Torx screws became common.. (6 pointed star) In any case, I'd suggest to first positively identify how many points on the "star" of the head... It'd be either a 12 point socket or an inverted torx socket you'd need. 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #3 Posted July 31, 2023 1 hour ago, Gasaholic said: Been at least 25 years since I worked on them but yes, 12 point socket - I believe it was a 12-point socket that we at the time had to run the O.D. down a tiny bit on a grinder to get it to fit in some of the recesses.. I think it was before Inverted Torx screws became common.. (6 pointed star) In any case, I'd suggest to first positively identify how many points on the "star" of the head... It'd be either a 12 point socket or an inverted torx socket you'd need. That's what I was thinking , well looks like i'm going socket hunting , lol Thanks for the info Share this post Link to post Share on other sites
pfrederi 18,322 #4 Posted August 1, 2023 A 1/4" drive 12pt 1/4 inch socket will usually work/.. Mine is a Proto tool 4708T 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #5 Posted August 1, 2023 3 hours ago, pfrederi said: A 1/4" drive 12pt 1/4 inch socket will usually work/.. Mine is a Proto tool 4708T Yep , I think I have at least 50 different 1/4 " sockets , lol not one 12 point 1/4 " . I now have a full set of them . I'll get those little boogers now . Share this post Link to post Share on other sites
