Mike in NC 342 #1 Posted July 30, 2023 This is my show find from this past weekend in the line of Wheel Horse. How do you tell what model it is and around what year would it have been made? The blade is bent, but that is fine. I will work on it toi get strightened out. I have wanted one for several yaers and finally found one. What model tractor whould this have been made for? Thanks in advance!! Mike 2 2 Share this post Link to post Share on other sites
ineedanother 1,369 #2 Posted July 31, 2023 2 hours ago, Mike in NC said: This is my show find from this past weekend in the line of Wheel Horse. How do you tell what model it is and around what year would it have been made? The blade is bent, but that is fine. I will work on it toi get strightened out. I have wanted one for several yaers and finally found one. What model tractor whould this have been made for? Thanks in advance!! Mike Good find Mike. I don't need a grader very often but I have my eye out for one and know they're a rare bird in NC. I can't help with the model and fit but hope to see what you do to get it back in service 1 Share this post Link to post Share on other sites
rjg854 11,623 #3 Posted July 31, 2023 It will fit almost any tractor that has the mid-tachomatic 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,154 #4 Posted July 31, 2023 This should be all of them but will be in no particular order https://www.wheelhorseforum.com/search/?&q="Blade Grader Pulled 40in"&type=downloads_file&search_and_or=or&sortby=relevancy 1 Share this post Link to post Share on other sites
ebinmaine 69,239 #5 Posted July 31, 2023 Excellent find ! 1 Share this post Link to post Share on other sites
squonk 41,739 #7 Posted July 31, 2023 You can tell by the WH decal that it's a mid 60's to early 70's blade. Mid 70's they switch to the large WHEELHORSE script 2 1 Share this post Link to post Share on other sites
Mike in NC 342 #8 Posted August 2, 2023 I guess I need to find teh mounti8ng brackets for my Bronco 14. 1 Share this post Link to post Share on other sites
Mike in NC 342 #9 Posted August 5, 2023 (edited) Thank you everyone. I notice that it must be a Model 7-1112 or newer as of the angleing handle. I did not see a tag on it or where one would have been, I did notice that it is missing the lift arm, which I see Wheel Horse Parts and More sells. I might try this one my 312-H in the mean time. I didn't really need it, but I look for the unusal things. A friend had it and priced it at $100, so I could not pass it up, even if it is bent. I will work on that here soon. Edited August 6, 2023 by Mike in NC 3 Share this post Link to post Share on other sites
Mike in NC 342 #10 Posted August 6, 2023 Since I had the mower deck off fo the 312, I put the center grader blade on it and tried it out. It worked ok, but I wqs playing around in some real hard dirt. It will look cool as a display at one of the local shows. I have a Cub Cadet with a rear mount rototiller that gets people attention. I hope the grader blade does the same thing. 1 Share this post Link to post Share on other sites
ebinmaine 69,239 #11 Posted August 6, 2023 12 minutes ago, Mike in NC said: Since I had the mower deck off fo the 312, I put the center grader blade on it and tried it out. It worked ok, but I wqs playing around in some real hard dirt. It will look cool as a display at one of the local shows. I have a Cub Cadet with a rear mount rototiller that gets people attention. I hope the grader blade does the same thing. It will. Folks find it oddly fascinating that such a "small" machine can be used to WORK. 1 Share this post Link to post Share on other sites
