ebinmaine 75,774 #1 Posted July 30, 2023 Our Wally Digger Backhoe needs a muffler. This machine has the original Wheelhorse muffler that lays horizontally with a single input off an S shaped piece of iron as an adapter from engine to muffler. I believe that adapter outlet points straight out. I'm thinking about using a Gravely replacement type so it'll be lightweight and reasonably quiet. Any other suggestions? 1 Share this post Link to post Share on other sites
ri702bill 10,578 #2 Posted July 30, 2023 Put a stack on that Bad Boy - ask @Pullstart !!! 1 1 Share this post Link to post Share on other sites
ebinmaine 75,774 #3 Posted July 30, 2023 24 minutes ago, ri702bill said: Put a stack on that Bad Boy - ask @Pullstart !!! Love stacks but this is a FEL. No room for a stack. 2 Share this post Link to post Share on other sites
Pullstart 68,529 #4 Posted July 30, 2023 EB. No pics? 2 Share this post Link to post Share on other sites
ebinmaine 75,774 #6 Posted July 30, 2023 59 minutes ago, Pullstart said: EB. No pics? Got some for ya. Here's the old muffler. Here's the amount of space and pipe sizing. Looks like just under 1.5" OD. Tape is pointing to the outlet for reference. 1 Share this post Link to post Share on other sites
Pullstart 68,529 #7 Posted July 30, 2023 Is there something wrong with the stock one? 1 Share this post Link to post Share on other sites
ebinmaine 75,774 #8 Posted July 30, 2023 2 minutes ago, Pullstart said: Is there something wrong with the stock one? At shutdown the machine backfires LOUDLY. Having had issues with mufflers causing that in the past I got to looking at it. There's an extra hole on the outside at one end, a soft spot on the inside at the other, and it's very rusty crunchy overall soft. Whether it solves the backfire or not this muffler is gonzo... 1 Share this post Link to post Share on other sites
Pullstart 68,529 #9 Posted July 30, 2023 Have you had the head off to decarbon and inspect the valves? 2 Share this post Link to post Share on other sites
ebinmaine 75,774 #10 Posted July 30, 2023 5 minutes ago, Pullstart said: Have you had the head off to decarbon and inspect the valves? No sir not yet. That'll be done this fall/winter with other work we do. 1 Share this post Link to post Share on other sites
Pullstart 68,529 #11 Posted July 30, 2023 2 minutes ago, ebinmaine said: No sir not yet. That'll be done this fall/winter with other work we do. I’d put at least a one dollar Bob wager on that being an issue… 2 Share this post Link to post Share on other sites
wallfish 18,788 #12 Posted July 31, 2023 2 hours ago, ebinmaine said: At shutdown the machine backfires LOUDLY. Shut it off with the throttle wide open 2 Share this post Link to post Share on other sites
kpinnc 16,201 #13 Posted July 31, 2023 (edited) 4 hours ago, ebinmaine said: At shutdown the machine backfires LOUDLY. All of mine do that unless I throttle back to idle for a few seconds before shutdown. I see @wallfish mentioned full throttle. I guess it's how rich the old Kohler is running at both ends of the throttle range. Edited July 31, 2023 by kpinnc 3 Share this post Link to post Share on other sites
ebinmaine 75,774 #14 Posted July 31, 2023 8 hours ago, wallfish said: Shut it off with the throttle wide open 5 hours ago, kpinnc said: All of mine do that unless I throttle back to idle for a few seconds before shutdown. I see @wallfish mentioned full throttle. I guess it's how rich the old Kohler is running at both ends of the throttle range. I actually do both. I bring it down to idle. Wait 5 or 10 seconds. Turn the key off then bring the throttle up to full. Share this post Link to post Share on other sites
CCW 1,454 #15 Posted July 31, 2023 (edited) 17 hours ago, ebinmaine said: Got some for ya. Here's the old muffler. Here's the amount of space and pipe sizing. Looks like just under 1.5" OD. Tape is pointing to the outlet for reference. So this the same muffler I just replace that you gave me input on. I purchase the "Rotary 8284 Clamp-On Muffler for Kohler" from the A..zonian website. Only problem is took a couple of weeks to arrive. I had to buy a 1.5 ID coupler and another muffler clamp to attach it to the exhaust outlet pipe on the Magnum 12. Edited July 31, 2023 by CCW 1 Share this post Link to post Share on other sites
8ntruck 8,346 #16 Posted August 1, 2023 If I remember correctly, turbochargers work as rudimentary mufflers. 1 Share this post Link to post Share on other sites
ebinmaine 75,774 #17 Posted August 1, 2023 5 hours ago, 8ntruck said: If I remember correctly, turbochargers work as rudimentary mufflers. And that neat whine.... Share this post Link to post Share on other sites
