peter lena
firm foam back support , cold gel pad
peter lena
@davem1111  , been thru a lot of phases to body ache , boat seat foam , is very firm , its also a life saver , have a 15" square  1 ,1/2 "  thick , hard back chair , foam pad on your lower back , with a  large frozen gel pad up against your pain point , that is a aregular for me , breaks the pain cycle , and lets me expore movement gain . with the gains made in  movement therapy , its let me gain on my  issue . just a suggestion , pete
peter lena
@Treepep , @ebinmaine  had both of my knees done years ago , therapy is vital on a restart , could not kneel on a hard serface , till I  found boat seat foam pieces in a bin at a marine boat shop . odd shapes thicknesses . but I  could kneel on them  easily . great for the kneeling leg muscle pull stretch , that helps your back . showed it to the therapist , he loved it , said it was the perfect push back resistance to a joint. pete
Sparky
  So you’re saying there isn’t a lube available for old knees !! Dang-it!
  Just messing with ya Pete :handgestures-thumbupright:
  • Haha 2
ranger
Great things these, even my doggy has one, + his own personal cordless fan! IMG_1111.jpeg.089226747c5fd550753b27bac301c9a9.jpeg
Mickwhitt
I use an acupressure pad for back pain. It's a thin mat with plastic spikes on its surface.
You lay on it bare skin to the spikes.
It hurts like hell for a few minutes until you get used to it. But it soon feels pretty dull.
The idea is it increases blood flow to the painful area and encourages healing.
Works for me.
127916416_Screenshot_20230804_204739_SamsungInternet.jpg.39346136e6c9e201b68686be5a559c80.jpg
peter lena
@Mickwhitt  yes when you wake up / siimulate a body area , thats the time to take advantage of that . theripest  I  was working with , would regularly add / change movement range to a gain , or easement .  did a lot of flat rubber pull straps , in the knee area / ankle area , to side step , and slow walk foward / backward , to enhce  hip areas and upper leg muscles .  have a definete  gain  in movement , from where I  was . pete
