Bob Bauer 27 #1 Posted July 27, 2023 Hello, I’m flushing a 5003 transmission and ran some diesel fluid through there and was wondering if I could just put it up on my parts cleaner and run the fluid through it to do a better job or just stick with the diesel? Don’t want to mess anything up.thanks Share this post Link to post Share on other sites
stevasaurus 23,515 #2 Posted July 27, 2023 This really depends on how much gunk is in there. If there is a lot and it has been in there forever, no amount of flushing is going to really clean it out. If no body has ever been in it, I'll bet you have some rust (at least from condensation)...flushing will not clean out that. It would be better if you took off the brake shaft side plate and took a look. Then you could see what you've got and maybe running your parts cleaner would be a good option. Remember, right now you are trying to drain out gunk through a 1/4" hole...not a very efficient way to do things. BTW, you have a couple of good neighbors near you...maybe they will chime in. @WHX?? @Achto 4 Share this post Link to post Share on other sites
Achto 30,194 #3 Posted July 27, 2023 3 hours ago, Bob Bauer said: wondering if I could just put it up on my parts cleaner and run the fluid through it to do a better job or just stick with the diesel? Unless you are going to take it apart to do a complete scrub down, I think you would be better to continue with the diesel flush. Put diesel in the tranny, drive it around for 10 to 15 min, drain it, repeat until you are satisfied with it. Share this post Link to post Share on other sites
Bob Bauer 27 #4 Posted July 27, 2023 17 minutes ago, stevasaurus said: This really depends on how much gunk is in there. If there is a lot and it has been in there forever, no amount of flushing is going to really clean it out. If no body has ever been in it, I'll bet you have some rust (at least from condensation)...flushing will not clean out that. It would be better if you took off the brake shaft side plate and took a look. Then you could see what you've got and maybe running your parts cleaner would be a good option. Remember, right now you are trying to drain out gunk through a 1/4" hole...not a very efficient way to do things. BTW, you have a couple of good neighbors near you...maybe they will chime in. @WHX?? @Achto Ok good to know, thanks alot 1 Share this post Link to post Share on other sites
Bob Bauer 27 #5 Posted July 27, 2023 1 hour ago, Achto said: Unless you are going to take it apart to do a complete scrub down, I think you would be better to continue with the diesel flush. Put diesel in the tranny, drive it around for 10 to 15 min, drain it, repeat until you are satisfied with it. Thanks Share this post Link to post Share on other sites
Handy Don 15,183 #6 Posted July 27, 2023 And please properly dispose of the contaminated diesel! 1 Share this post Link to post Share on other sites
Pullstart 68,524 #7 Posted July 28, 2023 2 hours ago, Handy Don said: And please properly dispose of the contaminated diesel! I’m not a blue oval guy, but when I had an ‘01 Power Stroke I filtered many thousand gallons of used oil, fry or automotive, through a 10 micron then 5 micron system and into the truck. Straight WVO and all, it did great! 1 1 Share this post Link to post Share on other sites
