mort 24 #1 Posted July 25, 2023 My 418A will run in forward and backward but mid mount hydraulic lift not working at all. What are possible problems/fixes? Also it sounds like the forum has suggested putting in 10W 30 Synthetic oil in this automatic transmission. Should I be concerned about the gasket leaking using synthetic oils? Why not 10W 40 Synthetic instead? I have never used synthetic oils in anything so I am just curious. Thanks, Mort Share this post Link to post Share on other sites
Ed Kennell 43,771 #2 Posted July 25, 2023 (edited) 12 hours ago, mort said: hydraulic lift not working at all Is the piston not moving? Is the linkage intact on the control valve lever? I use 30w Super Tech in all my Eaton 1100s. .Super Tech Non-Detergent SAE 30W Lubricating Oil, 1 Quart - Walmart.com Edited July 25, 2023 by Ed Kennell 1 Share this post Link to post Share on other sites
mort 24 #3 Posted July 26, 2023 Piston not moving but valve lever seems fine. This tractor has been sitting under my decking so there could be some rust but it looks fine. I didn't see 30W listed in my manual for the automatic transmission oil. Is there a reason why you use 30W instead of the recommended 10W30 or 10W40? Thanks, Mort Share this post Link to post Share on other sites
lynnmor 8,238 #4 Posted July 26, 2023 You can use whatever 10W-30 you want, I use Castrol High Mileage semi-synthetic for the extra additives. Share this post Link to post Share on other sites
Ed Kennell 43,771 #5 Posted July 26, 2023 11 hours ago, mort said: Is there a reason why you use 30W instead of the recommended 10W30 or 10W40? This oil is used to operate the hydro transmission and hydraulic lift systems where fluids of a wide range of viscosity (ATF, hyd jack oil, 10w-30 motor oil.) have been used in many cases. This same oil is also used to lubricate the differential where a thicker oil (90-140w) is recommended. I currently have three of the Eaton 1100 transmissions in use. Most of the hours are mowing duties where the temps are 70-90F. During the winter months, the snow machines are kept in a heated garage so there are no cold starts. BTW, two of the Eaton 1100s pump immediately and one requires a warm up before pumping. Wheel Horse recommends a warm up of all Eatons before using. I just feel the 30w is better for the differential gears, seals, and bearings and I see no ill effects to the hydraulic pumps. 1 Share this post Link to post Share on other sites
mort 24 #6 Posted July 26, 2023 33 minutes ago, Ed Kennell said: This oil is used to operate the hydro transmission and hydraulic lift systems where fluids of a wide range of viscosity (ATF, hyd jack oil, 10w-30 motor oil.) have been used in many cases. This same oil is also used to lubricate the differential where a thicker oil (90-140w) is recommended. I currently have three of the Eaton 1100 transmissions in use. Most of the hours are mowing duties where the temps are 70-90F. During the winter months, the snow machines are kept in a heated garage so there are no cold starts. BTW, two of the Eaton 1100s pump immediately and one requires a warm up before pumping. Wheel Horse recommends a warm up of all Eatons before using. I just feel the 30w is better for the differential gears, seals, and bearings and I see no ill effects to the hydraulic pumps. Thanks! Maybe I need a warm up for the hydraulic lift to run. I have only used a 310-8 and a 416-8 so I don't have any experience at all with automatic transmissions. Thanks, Mort Share this post Link to post Share on other sites
mort 24 #7 Posted July 26, 2023 3 hours ago, lynnmor said: You can use whatever 10W-30 you want, I use Castrol High Mileage semi-synthetic for the extra additives. Just read about that Castrol oil. Looks like good stuff. I bought high mileage Mobil 1 10W-30 synthetic last week but maybe I should return it for Castrol. I like the conditioner idea for leaks. I do have something leaking. Thanks, Mort Share this post Link to post Share on other sites
c-series don 10,777 #8 Posted July 27, 2023 @mort I don’t believe you have fixed the lift problem? Does it make noise when you move the lift lever? Is the cylinder moving at all? Share this post Link to post Share on other sites
