Countdown To Christmas!
850ford
1980 C165
850ford
I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
Will a standard mount Kohler work, if I remove the cradle?
 I am located in Massachusetts
  Thanks
Rick3478
First off, I think you can swap oil pans and put your replacement motor on the cradle.
But more directly to your question, probably yes but you may need to drill holes in the frame rails.  And you will also need to add the lower bracket that the PTO clutch hoop pivots in.  And of course source a few nuts, bolts, and washers to hold it together.  That's what comes to mind off the top of my head.
Edited by Rick3478
improve clarity
  • Like 3
Ed Kennell
I agree with all Rick has said.   Not sure, but you may need a different PTO hoop if you eliminate the cradle.     It is probably easiest to keep the cradle and change the oil pans.
If you decide to use the cradle, I would change it to a solid mount by replacing the rubber with solid spacers.
  • Like 4
kpinnc
The frame rails should be the same for a standard 2 quart oil pan typically used on Wheel Horses. The cradles used the regular bolt pattern to mount to the frame.
But- Wheel Horse used oil pans that were drilled all the way through on the two PTO side mounting holes. You can easily make any deep oil pan work, but you will have to tap the holes all the way through. I start with a 1/8 bit and drill from the top of the existing holes (use a drill press, the taper of the factory hole will center the bit), then repeat with a 5/16 bit. Then thread with a 3/8x16 tap. Just start at the top, chasing the existing threads, and go all the way through.
Edited by kpinnc
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
