Al C.
Fuel pump
Al C.
Recently I have needed to prime the fuel line before starting my Wheel Horse SK-486.  There are no leaks, so I’m not sure what has changed.  Can anyone recommend an electric fuel pump (brand/model) for a Koehler K341 16hp engine?
ebinmaine
Facet makes a good pump.
Some things to consider first though.
It's important to verify the actual issue.
Disintegrating fuel line or dirty needle & seat and cause that issue.
Do you use non-ethanol fuel?
When was the last time every single component of the fuel system was removed, replaced or cleaned?
Al C.
A very long time.  Sounds like I have some work to do ?
ebinmaine
Many many moons ago a relatively sharp person taught me that we have to focus on doing the maintenance before we try doing any diagnostics or tossing Parts at things.
Because of the fact that we've been trying to burn alcohol in our gasoline for a decade or more there will be different types of damage than what we were used to in the past.
  • Like 4
Achto
Al C.
I do not use non-ethanol fuel.  I agree about doing the appropriate maintenance first.  Help me understand what this realistically involves … removing, disassembling and cleaning the carburetor, removing, disassembling and cleaning the old fuel pump, replacing the old fuel lines to the gas tank ???  Am I on the right track?   What are the gotcha’s I should be aware of?   Thanks!
IMG_6229.jpeg.30a017d927830bfd1328bca0b4d92835.jpegIMG_6227.jpeg.19318677c53f55bf715a148dbfeead0c.jpegIMG_6228.jpeg.1fc662abf56f502db4af155c6203c006.jpeg
Edited by Al C.
ebinmaine
Yeah buddy that's it....
I don't have any of those newer models so I can't speak for sure.
D_Mac
you can pull the fuel line at the carb and put the line in a jar, crank the engine and see how its pumping. I agree with eric, clean your fuel system, new lines, filter and a carb cleaning and it will be running like new.
  • Like 4
D_Mac
wait a minute .......... they make newer ones ?
  • Haha 3
ebinmaine
Now that I think about it the Wally Digger Backhoe is a 1986 but we haven't started messing with that yet.
Not counting that beautiful piece of machinery my latest model would be a 1975.
D_Mac
Until i picked up my Free10-8, thats an 87. My other 3 are 1965, 1965 , 1966.
peter lena
@ D-MAC agree with others on the fuel cleaning detail , https://www.amazon.com/CarBole-Universal-2-3-5P-S-I-Operating-Self-Priming/dp/B01IR6BNKY/ref=asc_df_B01IR6BNKY/?tag=hyprod-  also have a couple of these in service model #  P/N 42 S low pressure pump . noting your vertical run fuel hose , from pump to carb , have a vertical flow check valve in my 3 kohlers , evil energy brand , look at the staged fuel to your carb . BTW  use ethenol fuel , but also use , sta bil storage treatment in all my fuel , no black rubber fuel hose breakdown in my filters , or fuel bowls . we all have our own  set ups , regularly brought on by frequent failures . hope you make out , pete
squonk
Al C.
UPDATE:  I took a stab in the dark.  Did the simplest thing first.  Replaced the original fuel pump with a compatible device off of Amazon.  It worked!  Fixed!
3A2906D5-52EA-4324-85BB-1F96F80EAE82-COLLAGE.jpeg.26912ae863d16282751217bf2f3f8589.jpeg
  • Like 5
