JR1
Mulch blades for Wheel Horse 310-8 with 42" deck?
JR1
HELP! :) Trying to find a set of mulching blades - Gator or other brand - to use on my Wheel Horse 310-8. It has a 42" deck model number 0542MR04.
THANKS!!
peter lena
@JR1  https://www.google.com/search?q=mulch+blades+for+wheel+horse+42"+deck&rlz=1C1CHBF_enUS866US866&oq=mulch+blades+for+wheel+horse+42"+deck&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIGCAEQRRg8MgYIAhBFGDzSAQkxNzg1NmowajSoAgCwAgA&sourceid=chrome&ie=UTF-8  how about this ?  many options , lots of places to look / shop, also look over what you have for the best mower deck drive set up, usually rough/ rusty , needing service , can you move the existing pto belt drive by hand , easily ? of course the mower is off , not running . the easier you can make the pto  drive belt move , is telling you how it will function . others will add their views , pete
JR1
Yes ,I had done that, thanks. Many shown in that query are not for 42" and I should have asked that I was looking for a set of recommended mulching blades for my 310-8 with a 42" deck. :) Thanks.
TractorEd
I found some for a 36” deck.  I just measured the existing blades (length and center hole).  Then searched the interwebnet and found the right gator blades for it.  Sorry I dont know the length/diameter for the 42”, but I’ve been lucky to find them for a 60” and a 54” deck, too.  I hope you can do the same!
8ntruck
Deck blade length on Wheel Horse equipment is usually measured on the diagonal from the tip of one cutting edge to the tip of the other cutting edge.  I don't know if that is an industry standard that all companies use, but it is something to keep in mind when shopping for blades.
Lee1977
If you can't find them in Oregon blades you most likely won't find any.
Edited by Lee1977
